Okay question for all DSR1 gurus. - Road Glide Forums
post #1 of 1 (permalink) Old 04-21-2019, 10:16 AM Thread Starter
Heavy Metal's Avatar
DSR1 question. If your running woofers should you crossover on:
High Pass at @50hz - 63hz 48db or
run it on Band Pass at @50hz - 63Hz to 7Khz 24db slope.
Or Low Pass at 7Khz 48db?
Basically tuning it out of the Subwoofer Range. While using High Pass and letting it run out above it’s range in upper frequencies since
Horns or Tweeters will take over anyhow.
Have Hertz Millie MLK 1605.3( woofers domes only ) Legends( no crossovers uses ).
Hertz SV 200L
Hertz ST35
*Hertz ML1650.3
* Millie MLK 1650.3 Legends.
*Hertz ML 280.3
Heavy Metal is offline
DSR1 fuse????????? Luckys2018RoadGlideCustom Audio 5 02-03-2019 02:38 AM
Rockford Fosgate DSR1 signal processor thru your smartphone questions Luckys2018RoadGlideCustom Audio 1 02-02-2019 06:14 PM
Dsr1 RFG7680 Audio 2 01-13-2019 11:35 AM
DSR1 question Heavy Metal Audio 1 03-16-2018 11:48 AM
Question for paint gurus roadglide2010 Paint & Bodywork Section 5 11-22-2012 12:57 AM
