antenna wire location - Road Glide Forums
post #1 of 3 (permalink) Old 04-23-2019, 04:30 PM Thread Starter
2010yoda's Avatar
bought the bike and not much reception, pulled outer fairing found hd hidden antenna, original cable there from whip antenna, cannot locate other end at back of bike. is there a connector mid way or did they hack it off somewhere, it has the cvo rear fender with big led lights. any ideas? thanks
2010yoda is offline
post #2 of 3 (permalink) Old 04-23-2019, 05:23 PM
Glidin2013's Avatar
If your lucky, they may have tucked under the side cover. Is the bracket still on the rear where antenna mounted? Not sure how that worked. Never had CVO fender, so not sure what they did with antenna on the original CVO bikes. Other guys I am sure will chime in.
Glidin2013 is offline
post #3 of 3 (permalink) Old 04-23-2019, 07:57 PM
BH#103's Avatar
Should be a square white or off white plug end on top of the battery. It comes out of the wire carrier underneath the fuel tank usually offset to the left side more by the lighting plugs.
"SLIVER"
BH#103 is offline
Hidden Antenna Location? CantRider Audio 3 10-16-2017 09:30 PM
OEM GPS Antenna Mounting Location wevsspot GPS 6 08-14-2017 10:58 AM
tour pak wire harness hole location? Hellbent Paint & Bodywork Section 0 01-25-2015 06:44 PM
Fairing internal antenna location cobra206 Do-IT-Yourself 2 07-21-2012 09:15 PM
Hole in King Tour Pack for Antenna Wire Bud Seating: seats, backrests 6 03-13-2011 03:21 PM
