Apple car play on GTS - Page 3 - Road Glide Forums
 13Likes
post #21 of 31 (permalink) Old 04-25-2019, 11:36 AM
Originally Posted by skratch View Post
cause i don't have a whim, and i don't have a headset right now and don't have the funds to go out and purchase 2 (wife rides her own bike, so whatever we buy, we have to double). i will probably do so in the future, but i didn't want to not be able to take advantage of some of the CarPlay functions right now while i wait to get a headset.
so, i did check the function of pandora, and was able to cycle through the options using the thumb switches. i can change stations, etc. even add a thumbs up or down, but did not find any way to change genre. but, i can't find that option in my car either.
Ok thanks. That's what I was looking for is to be able to change stations not just skip ahead.
Sent from my SM-G955U using Tapatalk
ksbutler44 is online now
post #22 of 31 (permalink) Old 04-25-2019, 11:39 AM
craigffb's Avatar
Not saying this is the route to go, but you could do what you are saying with a wired headset by calling on the phone. And yes I know everyone hates the wired headsets.
craigffb is offline
post #23 of 31 (permalink) Old 04-25-2019, 11:42 AM
craigffb's Avatar
You SHOULD be able to do that. I don't care for Pandora so I don't use it. I use Spotify and I can change stations on it in the menus. If Pandora doesn't do it on the GTS CarPlay then it doesn't do it on any CarPlay...they are all the same.
ksbutler44 likes this.
craigffb is offline
post #24 of 31 (permalink) Old 04-25-2019, 11:46 AM
Ok I'll look into getting Spotify too thanks.
post #25 of 31 (permalink) Old 04-25-2019, 02:40 PM
jtspinner's Avatar
Can you work the apps through the handlebar switches ?
Yes you can work apps with handlebar controls. Just have to have iPhone plugged into USB port after having radio flashed to work without the headset.
jtspinner is offline
post #26 of 31 (permalink) Old 04-25-2019, 03:52 PM
skratch's Avatar
my bike doesn't have the setup for the wired headset either.
skratch is online now
post #27 of 31 (permalink) Old 04-25-2019, 04:31 PM
craigffb's Avatar
I figured that, the DIN connector is $65 and you can get brand new wired HD headsets all day because cats are selling them because they went blue tooth.
Not suggesting it one way or another by itís a way cheaper option then getting a WHIM and a Bluetooth headset for two bikes.
craigffb is offline
post #28 of 31 (permalink) Old 04-25-2019, 04:51 PM
skratch's Avatar
ah, i see. yes, you're right, it is very much cheaper. thanks for the heads up.
craigffb likes this.
post #29 of 31 (permalink) Old 04-26-2019, 07:34 AM
craigffb's Avatar
Also if you do decide to go wired you'll have to have the WHIM block turned back off. It kills the mic on the wired DIN connector.
And for the guys just getting access to CarPlay, I've found it best to plug in the phone AFTER the bike is running. Carplay seems to be a little finicky (at least on my bike) if I plug the phone in before I start my bike. Like apps not loading right, and non of the menus showing up.
craigffb is offline
post #30 of 31 (permalink) Old 04-26-2019, 07:53 AM
Thanks for the heads up
