No Sound on new system - Road Glide Forums
post #1 of 5 (permalink) Old 05-03-2019, 12:22 PM Thread Starter
Very green newbie here, just installed the CV B54 amp and front Polk mm1 and rear Polk (5X7) speakers on my 15 RGS. Everything works, shows artist, volume level, but no sound at all. I know it's something on me, do I need a flash to fix this or possibly line levelers to get sound, or is it possibly just a matter of fine tuning the controls. Had everything pre-wired plug & play which made it easier to install. Amp was set to 4 channel. It was pre-set to my set up but did say it needed tuning. I'm sure/hopeful it's a simple fix, Any help and/or advice would be helpful!
Bunkiehead is offline
post #2 of 5 (permalink) Old 05-03-2019, 12:33 PM
Pictures would help. Is the amp powering up ? Are the speakers hooked up out of the amp ? Plug & play isn't always such as..
Big_gary is online now
post #3 of 5 (permalink) Old 05-03-2019, 12:44 PM Thread Starter
I'm on that now, figured it would help after I posted.
post #4 of 5 (permalink) Old 05-03-2019, 01:53 PM
Spazz's Avatar
Best to get a flash and DONT TRY TO RUN IT AS IS.
2 amp ON - 8 speaker On flash
Then make sure your input selector on amp is set to 2 channel input first off. You only have front speakers enabled with factory config. And only output is for front 2 channels of deck.
Tuning:
Turn gains down to zero to start... HPF ON FOR ALL 4 CHANNELS with freqs set to around 50-60hz . Then turn volume up half way and slowly increase gain on front til you hear audio... then bring your deck to 4-5 bars from top and adjust your gains slowly until you hear distortion, then back it of bit.
If you dont have power to the amp.. ensure your switch wire is connected... unless its signal sensing capable... then make sure you have the amp dipswitch is in the correct location for signal sensing.
Btw... I have not dealt with that particular amp... so ... giving all options I can think of.
Sent from my SM-G975U using Tapatalk
RENO BAGGER AUDIO
Spazz is offline
post #5 of 5 (permalink) Old 05-03-2019, 03:59 PM
You mentioned maybe needing line levelers. How are you getting the signal from the radio to the amp now?
roadie13 is offline
Wanted a Change - Went for the Deep Sound SteadyEddie Intake and Exhaust 40 04-09-2018 08:58 PM
Full SE vs VH Exhaust System w/ Stage 2 Sound System RoadWolf1172 Intake and Exhaust 23 12-26-2017 01:33 PM
Finally, better sound for my 2015 RGX Fla Shark Audio 3 08-14-2015 04:56 PM
Can a weak battery make your sound system distorted? kyle31490 Audio 7 06-17-2015 08:14 AM
Help me make a Sound System complete shopping list! erikdsn Audio 27 05-21-2012 02:46 PM
