Absolutely frustrated - Road Glide Forums
 5Likes
post #1 of 41 (permalink) Old 05-22-2019, 06:09 PM Thread Starter
Doc_FYF's Avatar
First time posting so be gentle.
Over winter here in Canada I installed Cerwin Vega B52 amp (no intentions to add any other speakers aside from fairing), bt355, bike Tronics remote wire adapter and had it flashed by the dealer for a 4 speaker 0amp setup. I've gone through 2 sets of infinity Kappa 62.ix and now just blew one of my JL audios 609 I got to replace the Kappas. I can not for the life of me figure this issue out and I'm about ready to light the thing on fire.
I've gone over the wiring everytime and double checked all the amp settings. For some reason though they always blow on the highway
I can't keep sinking coin into speakers so if anyone has any ideas or suggestions I'm open..
2017 road glide special
Doc_FYF is offline
post #2 of 41 (permalink) Old 05-22-2019, 06:26 PM
Welcome to the forum.
How did you set your gains on the amp?
What are your crossover settings?
Default settings on the BT 355 or did you tweak?
Key word and tricky phrase - they always blow on the highway..........If your AVC is on, turn it off and promise to never use it again. If I had a dollar for everyone that uses it and smoked a set of speakers................
roadie13 is online now
post #3 of 41 (permalink) Old 05-22-2019, 06:41 PM Thread Starter
Doc_FYF's Avatar
I was sent this for setting the amp.
"Tuning the amp
First make sure all dials are turned all the way counter clockwise. That's going to end you in the 7 o'clock position.
All steps from here will refer to the time on the clock for an easy reference.
Sens dials should all be at 11 o'clock, that's the first S in Sens, front and rear on 4 channels amps.
The Freq dial should be at the following;
6.5 set to 1 o'clock that's the Q in Freq
6x9 set to 12 o'clock that's straight up and down.
Horns and tweeters turn the dial all the way til it stops clockwise
8s, depending on the 8 should be between 9 and 12 o'clock
All switches should be on HP"
That's how I set it. Bt355 I didn't touch the settings
As for AVC I believe it was off if I'm not mistaken I had to leave the garage before I burnt it to the ground
Now I have to get replacement speakers again and thinking.of going this route
Hertz Mille Pro 6.5" 200 Watts Coaxial
Doc_FYF is offline
post #4 of 41 (permalink) Old 05-22-2019, 06:56 PM
mastergunnera8's Avatar
"Tuning the amp
1st off welcome to the forum..secondly IMHO check out a full biketronics system..lifetime warranty also...there are a couple setups floating around the forums used...still has warranty...That is a good amp..but just sayin...good luck!!!
mastergunnera8 is offline
post #5 of 41 (permalink) Old 05-22-2019, 07:01 PM Thread Starter
Doc_FYF's Avatar
I appreciate that I just can't justify that price at the moment being Canadian sometimes sucks for aftermarket. Granted I probably.would have done it knowing I'd go through the set of speakers but thankfully 2 of them the company returned and refunded . I appreciate the suggestion though
Doc_FYF is offline
post #6 of 41 (permalink) Old 05-22-2019, 07:10 PM
Thereís nothing in your setup that screams let the smoke out to me. Tuning should always be as specific as possible to a speaker, but nothing you stated is outrageous.
If you have a meter, check out the tuning thread in the audio stickies of the other forum or take a look at YouTube, tons of info.
My moneyís still on the AVC as the root of all evil. The stock head unit will distort at volumes above 14/17 depending on the source, so Iím assuming you kept it at or below that. Iím also assuming you tuned with the bike running.
post #7 of 41 (permalink) Old 05-22-2019, 07:14 PM Thread Starter
Doc_FYF's Avatar
Yes was tuned with bike running, and at level 14/17. Maybe I didn't fully turn the AVC off.not sure once.i calm down I'll be going back out to check because I swear i turned it off. Next speakers will be the
Hertz Mille Pro 6.5" any feed back on those? And this time.ill use the dmm to fine tune the voltage
Doc_FYF is offline
post #8 of 41 (permalink) Old 05-22-2019, 07:33 PM
Are you looking at the 165.3 or 1650.3? They are very different speakers. I run the 1650.3 up front in both bikes so Iím a little biased. The new DB Motos are also getting good initial reviews as are the upper end beymas.
post #9 of 41 (permalink) Old 05-22-2019, 07:37 PM
madmat's Avatar
Welcome to the forum from Mass!
Good luck dialing it in.
The hertz mille pro's rock! I have them with the arc audio 600/4, great sound.
18 RGS Bonneville Salt Pearl
madmat is offline
post #10 of 41 (permalink) Old 05-22-2019, 07:49 PM Thread Starter
Doc_FYF's Avatar
I'm looking at the 165.3 trying to stay budget friendly since I just bought a.new Simpson mod bandit and well I'll probably.be divorced soon if I keep it.up
Doc_FYF is offline
Frustrated Bike running Erratically Woodman Troubleshooting for Road Glides 17 06-07-2017 09:14 AM
SO FRUSTRATED!!! Need help with front wheel allignment Steelerdude1 *General Road Glide Discussions/Pictures 12 07-22-2015 04:36 PM
Drago's S/C/S 4's Installed.....ABSOLUTELY SICK,...pics Nevadasun Intake and Exhaust 21 01-22-2012 10:55 AM
