Daisy chain effect - Road Glide Forums
post #1 of 3 (permalink) Old 05-24-2019, 03:53 PM Thread Starter
Daisy chain effect
2016 rgs - Will have to travel to get my bike flashed 4/0. Is this overkill until I can't get flashed? Will I degrade my signal?
2 amps (4180/2180), 6 speakers (4 BT 6.5, Pioneer Pro 6x9). Plan is to run everything off of the OEM 6.5 HU using bt355 and a series of RCA "Y" connectors. Splitting signal to 4180 (front/rear) and further spitting to the 2180. I have bt355 for the rear channel once it gets flashed.
GoatHD is offline
post #2 of 3 (permalink) Old 05-24-2019, 08:08 PM
LoneCabbage's Avatar
Give Biketronics a call, Mike has developed a flash module for their customers that allows you to flash the radio yourself. You can either rent it or buy it from them. I just installed one of their amp and speaker kits and used it to flash mine and it works great.
LoneCabbage is offline
post #3 of 3 (permalink) Old 05-24-2019, 08:12 PM
RFG7680's Avatar
I have the BT 2180.15 set up. I'm not flashing my system. it sounds perfect with the line levelers alone. You may need to. But setting it up first you may not. Unless you need to change it to 4 from 2.
RFG7680 is online now
Cam Chain Tensioners Taz_FL Engine Related 12 06-16-2018 08:53 PM
Which Swingarm and Chain Drive? the24v *General Road Glide Discussions/Pictures 17 11-19-2017 09:11 AM
How To Adjust A Motorcycle Chain Motorcycle.com *General Road Glide Discussions/Pictures 7 06-28-2016 12:02 PM
David Yurman Shark Pendant and chain HogWild Miscellaneous for Sale 0 03-31-2016 09:19 AM
TC 88 Cam chain tensioners after 12,300 miles prince *General Road Glide Discussions/Pictures 5 03-19-2012 09:32 AM
