Two speakers not working - Road Glide Forums
post #1 of 6 (permalink) Old 06-14-2019, 09:03 PM Thread Starter
Jarhead66's Avatar
Hi everyone. So I put new handlebars on my 15 RG CVO
The front right speaker and the left rear speaker are not working. I’m not sure if it has to do with the handlebar swapped. Just bout the bike so I’m not sure if they were like that already or not. Any suggestions is appropriate. Thank you!
Jarhead66 is offline
post #2 of 6 (permalink) Old 06-14-2019, 11:44 PM
I donít think it is related. Also those speakers are known to die quite often.
Researching Road Glides
eggwhite93 is online now
post #3 of 6 (permalink) Old 06-15-2019, 05:17 AM
Ohiobellboy's Avatar
No problems with mine at 5 years old almost.
OP, swap the speakers side to side to see if the trouble follows the speaker. If the same speakers still don't work, it's the speakers. If not, could be the amp or wiring.
A.K.A OBB
Ohiobellboy is offline
post #4 of 6 (permalink) Old 06-15-2019, 06:44 AM Thread Starter
Jarhead66's Avatar
I swapped the rear speakers and both work. I didn’t realize if had a amp. Where’s the amp located? If it’s the amp it should be cover by the extended warranty right?
post #5 of 6 (permalink) Old 06-15-2019, 07:46 PM
Originally Posted by Jarhead66 View Post
I swapped the rear speakers and both work. I didnít realize if had a amp. Whereís the amp located? If itís the amp it should be cover by the extended warranty right?
Amp is under the radio in the fairing. Mine was covered by ESP when it went bad.
A.K.A OBB
post #6 of 6 (permalink) Old 06-16-2019, 05:59 PM
EJM05's Avatar
I would check your fuse as well.
EJM05 is offline
