Don’t post much but I’m definitely on here a lot. Figured I’d post my audio stuff that I’m doing to my 17. Some of you may remember my 12 in which i had 8 speakers, 2 horns and 3 amps. This bike is going to be more tamed than that one, at least for now. I’ll be running two Faital Pro 6.5 coax in the front with the woofer parts run off a Soundigital 600.1 and the “horn” parts run off a Soundigital 250.2. Then in the rear I’ll be running two PRV 10s running off a Soundigital 1200.1. All amps will be mounted in the fairing. Will also be running a Rockford DSR1 to fine tune everything. My plan as of now is to run a dual circuit breaker, one side for front and one side for rear, so that i can easily turn off the rear section on long trips and rides. I’m just getting started with bonding my 10” rings in the bags and getting my amp rack done in the fairing. I’ll update as i go as I’m trying to get some preliminary stuff done so once i open the fairing i can roll on everything, saving my down time.
