Tweeter and SV 165 question - Road Glide Forums
post #1 of 2 (permalink) Old 07-21-2019, 07:32 PM Thread Starter
Hey guys. First I'm a newb to component wiring but I just purchased a set of Hertz SV 165 and a set of Hertz mp25.3 tweeters. I'll be using the American hard bags mount to "float" the tweeter across the SVs. Powering will be BT4180 for the 6.5s and the tweeters will be powered with a soundigital 250 2d amp. Question is these SVs are I guess a PA type speaker and will the tweeter be ok mounted in front of those? Or is this just a bad idea? The head unit is an Alpine w967hd double din Nav. It has what's supposed to be a great EQ and processor. I really dont know how to even use it. Sorry I'm a true newb. Previous bikes were stock head units with plug and play systems.
I've already mounted the 6.5s in the fairing. Just waiting on a cable and the bass blockers to come in Monday.
Any wiring and tuning advice would be greatly appreciated!!
Timber0472 is offline
post #2 of 2 (permalink) Old 07-23-2019, 10:22 AM
wevsspot's Avatar
The tweeter will be fine mounted "floating" above the mid 6.5
Since you're using dedicated AMPS to drive the mids and the tweeters, tuning should fairly simple.
wevsspot is offline
