Replacing Stock Speaker ? - Road Glide Forums
 3Likes
post #1 of 13 (permalink) Old 07-31-2019, 02:20 PM Thread Starter
I have a stock setup in my 18 RGS, but would like better speakers for clarity at higher volume. What speakers would be a good replacement for the stock speakers. Or would it be just a waste of money?
I realize an amp makes a great difference, but I do not want to go that route. I only listen using the speakers when traveling and want to save my wireless battery on long day trips.
Any suggestions would be appreciated
FLTRXS18 is offline
post #2 of 13 (permalink) Old 07-31-2019, 02:36 PM
Spazz's Avatar
The Infinity Kappa 62.11i would be your choice with the system being stock and 2 ohms...
Sent from my SM-G975U using Tapatalk
Swomack and Painey01 like this.
RENO BAGGER AUDIO
Spazz is offline
post #3 of 13 (permalink) Old 07-31-2019, 04:44 PM Thread Starter
^^^^^thanks^^^^^
FLTRXS18 is offline
post #4 of 13 (permalink) Old 08-05-2019, 09:54 AM Thread Starter
It seems the Infinity Kappa 62.11i are no longer available. I checked the auction site and other sites, did not find this model. When I did find the listed model, it showed no longer available. I called Infinity and was told they do not offer that model any longer and did not have a replacement, that is what I was told.
Any suggestions on another good speaker setup for a stock HD setup?
Thanks
FLTRXS18 is offline
post #5 of 13 (permalink) Old 08-05-2019, 10:30 AM
Spazz's Avatar
Thanks
If you are sticking with ALL STOCK (no amp) any 6.5" 2 ohm speaker you can find out there should work. Just remember... some of them require lots of power to push them... and just a stock deck may not be enuf.
I would save up and get a good system with 2 speakers and an amp to start and build from there. I offer upgrade to gon in stages.. say your end goal is 4 speakers... start with 2 speakers and amp... save up and add to it later... for example
RENO BAGGER AUDIO
Spazz is offline
post #6 of 13 (permalink) Old 08-05-2019, 11:15 AM
08Zinc's Avatar
Spazz makes a great point. Get the amp to push decent speakers, or you will throw good money after bad. Take a look at Arc Audio or Biketronics. I wasted a lot of money replacing speakers, upgrading to Boom 2!, another set of speakers, and then finally Arc Audio MPAK 12 before I was happy.
Blessings, Zinc -
08Zinc is offline
post #7 of 13 (permalink) Old 08-05-2019, 12:10 PM Thread Starter
Thanks for the info.
FLTRXS18 is offline
post #8 of 13 (permalink) Old 08-05-2019, 12:46 PM
wevsspot's Avatar
You don't need to spend a bunch of money to improve the stock audio system x100.......................
Keep your factory 6.5 head unit
Buy NVX VADM2 Amp
https://www.nvx.com/vadm2/
Buy x2 MMATS PA601cx coaxial speakers
https://www.mmatsproaudio.com/site/product/pa601cx/
(spring for the water resistant coating, but you don't need rings or grills)
Buy BT355 Line Out Converter
BT355 HD Radio Line Leveler And Pre-Amp Adapter for 2014 and Up - Biketronics Inc
You can be all in for right around $475 plus the nominal cost of installation parts (figure $40 or less there)
wevsspot is online now
post #9 of 13 (permalink) Old 08-05-2019, 01:44 PM Thread Starter
^^^^^thanks^^^^^
FLTRXS18 is offline
post #10 of 13 (permalink) Old 08-05-2019, 07:43 PM
Buy NVX VADM2 Amp
Great advice! And I see you are from FL. If you are anywhere near me over here in the panhandle I can help you install it.
Researching Road Glides
eggwhite93 is offline
