Stock upgrade? - Road Glide Forums
 3Likes
post #1 of 20 (permalink) Old 08-29-2019, 08:20 AM Thread Starter
R.Duck's Avatar
Stock upgrade?
This 06 has stock audio and the speakers are just junk and distorted.
I don't want to upgrade anything but the speakers no amp. What is a good quality sound speaker and should I get the adapter for the larger speaker or stay stock because I do not have a amp.
Trying to stay under $150 Hogtunes was one suggestion they run about $130
Any input is appreciated
Sent from my SM-G955U using Tapatalk
R.Duck is offline
post #2 of 20 (permalink) Old 08-29-2019, 09:30 AM
Spazz's Avatar
go 6.5" or dont waste your money...You will need 5.25" to 6.5" adapters for around $50
Then find a set of Infinity Kappa 62.11i
They are not made any more but there are a few sets out there still... best bang for your buck w/o an amp
You MUST stick with 2 OHM speakers unless you add an amp
Sent from my SM-G975U using Tapatalk
RENO BAGGER AUDIO
Spazz is offline
post #3 of 20 (permalink) Old 08-29-2019, 12:11 PM Thread Starter
R.Duck's Avatar
Not seeing anything out there 2ohm in 6.5
Mostly 5x7
R.Duck is offline
post #4 of 20 (permalink) Old 08-29-2019, 01:15 PM
Spazz's Avatar
Mostly 5x7
Search infinity Kappa 62.11i and the new ones come up... google is your best friend... there are some refurbished ones for around $80 that pop up
Also.. Amazon had the Infinity Kappa 62.IX for $99 and PRIME
Infinity Kappa 62IX 6.5" Coaxial Speaker System
madmat likes this.
RENO BAGGER AUDIO
Spazz is offline
post #5 of 20 (permalink) Old 08-29-2019, 04:53 PM
Infinity Kappa 62IX 6.5" Coaxial Speaker System https://www.amazon.com/dp/B075ZHJ683..._bFbADbKTHJV5Q
Have you heard the new infinity 62IX ? Wonder how they compare to the 62.11i ?
post #6 of 20 (permalink) Old 08-29-2019, 07:53 PM
Spazz's Avatar
No... I have not. I just know from history that it was the go-to for a budget upgrade with no amp and I have heard the 11i's before...they are better than stock for sure
RENO BAGGER AUDIO
Spazz is offline
post #7 of 20 (permalink) Old 08-29-2019, 08:14 PM Thread Starter
R.Duck's Avatar
I guess my concern is they are listed as car speakers to where motorcycle speakers usually are listed as marine and water/moisture resistant. I will read up on them some more
R.Duck is offline
post #8 of 20 (permalink) Old 08-29-2019, 08:46 PM
J&M's
reds4 is offline
post #9 of 20 (permalink) Old 08-29-2019, 08:50 PM
Most all speakes today are water resistant. No paper cones anymore, they all are some type of poly. The marine speakers usually have the xover on the rear coated in a rubber booting.
The Infinity kappa 6211i are good speakers for the money. Mine got wet plenty of times and never had problems.
They can be had for as low as $50 .
post #10 of 20 (permalink) Old 08-29-2019, 09:01 PM
Spazz's Avatar
Marine doesnt equal motorcycle... marine grade mean water resistant.. as in for boats.
Just dont drown your bike in water when you wash it near the speakers and keep the stock grille material there and you will be fine.
RENO BAGGER AUDIO
Spazz is offline
