Carplay in and out - Road Glide Forums
 2Likes
post #1 of 16 (permalink) Old 11-25-2019, 10:07 PM Thread Starter
thedude's Avatar
Carplay in and out
I just got a 20 Limited. Hooked up phone and wired headset. CarPlay starts then stops repeatedly for a few minutes then it settles in and works fine until I stop, then the whole thing starts over again. Any idea what I am doing wrong?
thedude is offline
post #2 of 16 (permalink) Old 11-25-2019, 10:56 PM
engineman115's Avatar
Iím having the same problem with the wireless setup!!
engineman115 is online now
post #3 of 16 (permalink) Old 11-26-2019, 06:03 AM
Rauzer's Avatar
I dont know much about it, I'm planning on buying a 2020 Limited in the spring. From the little I've read on here about Carplay, it seems the WHIM, or lack thereof, could be your problem. I've also read that the dealer can flash your radio to enable the WHIM without actually installing it.
2011 Road Glide Ultra
Rauzer is offline
post #4 of 16 (permalink) Old 11-26-2019, 06:31 AM
Suggestions: Make sure you have the latest software download to the infotainment center.
I have the W.H.I.M/use wireless and not had any problems on my 2020 RGS.
FLTRXS20 is offline
post #5 of 16 (permalink) Old 11-26-2019, 08:09 AM
craigffb's Avatar
Make sure your cord is seated well at the headset. Mine does that every now and then.
craigffb is online now
post #6 of 16 (permalink) Old 11-26-2019, 12:32 PM
Spazz's Avatar
Not sure if this will help... if its cutting off, you may have your VOX on or the sensativity set too high...
Sent from my SM-G975U using Tapatalk
FLTRXS20 and ia15rgs like this.
RENO BAGGER AUDIO
Spazz is online now
post #7 of 16 (permalink) Old 11-26-2019, 07:14 PM Thread Starter
thedude's Avatar
[QUOTE=Rauzer;4692543]I dont know much about it, I'm planning on buying a 2020 Limited in the spring. From the little I've read on here about Carplay, it seems the WHIM, or lack thereof, could be your problem.
I don't know much about it either but my understanding is if you use the wired headset you don't need the WHIM.
The cable connection was my first thought but it all seemed to be connected correctly. I did talk to someone at the dealer today who said try a different cable from the phone to the usb. He said he had issues when using an aftermarket lightning cable. Going to try this over the weekend.
thedude is offline
post #8 of 16 (permalink) Old 11-26-2019, 07:18 PM Thread Starter
thedude's Avatar
I would try this if I had some idea what the VOX is. I'm guessing its for the mic? This is probably obvious but I'm not he most tech savvy guy.
thedude is offline
post #9 of 16 (permalink) Old 11-26-2019, 08:00 PM
craigffb's Avatar
[quote=thedude;4692725]
Next time it happens just give the end of the cord plugged into your helmet a push. Like I said mine does it every so often. Mostly when I take the helmet off and not unplugging it from the bike. When a lightning cable is on the frits it will usually charge but not transfer data at all.
post #10 of 16 (permalink) Old 11-27-2019, 12:03 PM
freezeland's Avatar
I’m having the same problem with the wireless setup!!
Makes two of us.
freezeland is offline
