Inner fairing speaker w/o cutting g;ove boxes - Road Glide Forums
post #1 of 7 (permalink) Old 02-04-2011, 03:07 PM Thread Starter
Greeting, this is my first post, but I have reading this forum for months, a great source of info. I am currently upgrading 2, 2008 rg's one mine, and one for my brother. I wish too put 5.25 speakers in the inner faiinr , i.e facing the fork tubes. I already have boom speakers in mine and J&m 7.25 in my brothers.These are replacements for the stock speakers. It appears 5.25 speakers will fit w/o cutting the boxes. But reading and reading I don't know which speakerd would give a bit more volume,or is it a waste of time and $ to use 5.25 as a second set of speakers. I will also be adding a arc or J&m 250w amps to the rg's. Is there much of a difference between speakers listed as front or rear speakers, the rears are less $, I have narrowed speakrs down too, h.d. boom 5.25, hog tunes but these have huge mags. on them is clearance a problem?/ J&m 5.25, bazooka, and hawg wired, they all about the same price, any suggestion or problems I may have ? thanks for any suggestion. pic's to follow once
peener is offline
post #2 of 7 (permalink) Old 02-04-2011, 04:38 PM
Look for some 6.5" low profile speakers. I have a pair of pioneer coax speakers located there and the fit fine with no interference from the glove boxes.
Mark B
2005 FLTRI
mark_bert is offline
post #3 of 7 (permalink) Old 02-04-2011, 06:00 PM
abone's Avatar
Send a message via Yahoo to abone
I upgraded to the HD Boom Audio in the fairing and it improved the sound, but not substantially. I didn't install an amp however, so that is what I will do next. If I was to do it again, I'd fit 6.5" in there somehow.
2010 RG
abone is offline
post #4 of 7 (permalink) Old 02-10-2011, 07:27 AM
Neano62's Avatar
I bought the Rockford Fosgate shallow mount coaxial, 6.5".
I was at my buds last nite cuttn up sum "Plastic" (inner fairing)
I'll post a pic or to this wkd., if I go back over to his hse.
You've got bout 2" to play with between your inner fairing and the glove box.
The clearance issues cum w/the grills that these speakers provide. Its a freakn tight ass fit!
[/IMG]
Neano62 is offline
post #5 of 7 (permalink) Old 02-15-2011, 12:34 AM
HD Parts Expert
PC PaiN's Avatar
I would def like to check out these pics when you get a chance.
PC PaiN is offline
post #6 of 7 (permalink) Old 02-15-2011, 05:06 AM
Peewee's Avatar
From what a good friend told me the Harley Boom sound better than the J&M in the 5 1/4 size. He had the J&M and swapped out for the Boom's. Haven't heard the Bazooka speakers, but I haev their amp (did a write up on it in this section), and like J&M they got a package w/ amp & speakers
"Know Thyself"
Peewee is offline
post #7 of 7 (permalink) Old 02-16-2011, 05:31 PM
allofus81's Avatar
Yep I installed Rockford Fosgates 6.5 low profiles in mine also. Get an amp for sure it helps alot I run a Wetsounds amp from Throttleup industries its marine grade same as the ARC just marine grade. May not be worth the extra money IDK but I didnt want to take a chance on a investment I want to work for a long time.
allofus81 is offline
Lower fairing speaker boxes. Effenglide Audio 8 08-10-2014 11:29 AM
Speaker cutting out Rig Magician Audio 2 08-01-2013 09:20 PM
