Bazooka Amp review - Road Glide Forums
post #1 of 29 (permalink) Old 02-10-2011, 07:48 PM Thread Starter
Peewee's Avatar
Bazooka Amp review
I, along with FlatBlackBastard are the proud owners of the amp made by Bazooka. The amp is a four channel 200w RMS/ 250w peak amp. He is my review thus far. Sorry, no pics, was pressed for time, but will take pics later.
First off, the complaints: The instructions leave a lot to be desired. You may find this hard to believe, but the instructions were written for the batwings. So, other than just basic info, not much good. Not a bunch of room. If you have added any extra wiring, you already know that we don't have a lot of spare room under our shark noses.
On to the install: The install was pretty well a snap (I think it took longer to remove the fairing). The amp/wiring harness is pretty well moron proof. There is a power wire that is to be hooked straight to the battery, complete with ting terminal and fuse! A ground wire (once again with ring terminal. Now the instructions said to run the ground wire to the ground on the tripe tree (this was a feature on older bikes, but not present on the newer ones). However, this is where having a sharknose is helpful. Just pick one of the four bolts for the fairing support (its a perfect ground) and the ring terminal fits the bolt. I had to remove my iPod interface and two-sided tape it to the inner fairing so that I had room for the amp on top of the radio. Make sure you turn the amp so that the heat sink fins run with the bike. When it came time to reinstall the outer fairing this is necessary so the the center bolt of the windshield has somewhere to go (took a few tries before I figured this out). The wiring harness is simply plug and play. Unplug the harness from the back of the radio, plug in the amp harness, and then plug the factory harness to the other side. Two other wiring plugs on the amp two different sizes, so no confusion. Then the hard part......putting the fairing back on!
The sound improvement: I haven't tweeked the system, as I have one more mod to go. But with the amp pretty close to being set at half way, and the volume on the radio at halfway, it is freaking killer!! I am running 5 1/4 inch speakers made by Kicker. The are similar to the ones made by J&M, but they carry a little more bass. I also have the acoustic foam made by J&M installled.
Future mod: I am going to do speakers in the fairing lowers and I have decided to go with the Harley 6.5's found in the CVO StreetGlide. I know that there are better speakers out there, but I have my reasons.
Overall review: I am very pleased and impressed with the system thus far. Ease of install and the sound is great! Crystal clear...the live version of Desparado is unbeieveable! I have not tested the sound at interstate speed, but around town, freaking awesome. After I hit some interstate miles, I will update, as when I get done with the additional speakers.
Hope this review helps
"Know Thyself"
Peewee is offline
post #2 of 29 (permalink) Old 02-10-2011, 08:46 PM
connector's Avatar
Thanks for that, gives us still waiting on the sidelines another choice.
09 FLTR 103 Stage III
connector is offline
post #3 of 29 (permalink) Old 02-10-2011, 09:03 PM
Rowdy's Avatar
Great review. Thanks for the info.
Rowdy
Rowdy is offline
post #4 of 29 (permalink) Old 02-11-2011, 05:01 AM Thread Starter
Peewee's Avatar
And just to help with volumne difference.....with normal riding around town I would have the volume about 2/3 of the way up (the iPod interface is a little quiter than the cd), now I only have it about 1/3 of the way up for the same volume
"Know Thyself"
Peewee is offline
post #5 of 29 (permalink) Old 02-13-2011, 08:58 PM
JonnyU
Guest
Posts: n/a
Hows the amp working out for you?
post #6 of 29 (permalink) Old 02-14-2011, 05:22 AM Thread Starter
Peewee's Avatar
I am still impressed with the outcome. I wish I had done a amp long before now, granted I didn't know what I was missing until now either! I really want my other parts here NOW so I can finish up the stereo. Putting the lowers on w/ speakers in them.
"Know Thyself"
Peewee is offline
post #7 of 29 (permalink) Old 02-14-2011, 05:31 AM
Osuno77's Avatar
Which amp did you buy of the bazooka? And from what I read, did it come with a special wiring harness?
Thanks
2007 XLC 1200 "Rosie"
2010 Vivid Black Road Glide "Clarice"
Osuno77 is offline
post #8 of 29 (permalink) Old 02-14-2011, 07:44 AM Thread Starter
Peewee's Avatar
The Bazooka model/part number is: MC-HD-AMK. It did come with a special wiring harness that is plug and play to the factory wiring harness. All you do is umplug the factory harness from the radio, plug in the Bazooka harness, and then plug the factory harness into the other end of the Bazooka harness. Hook up the power wire to the battery, and then the ground wire......and then your'e rocking!
"Know Thyself"
Peewee is offline
post #9 of 29 (permalink) Old 02-14-2011, 12:20 PM
jimmyo79's Avatar
Thanks for the very informative and unbiased write up. I recently purchased the same Bazooka amp and will be installing it to drive 4 Rockford Fosgate 6.5 speakers in the fairing as soon as my Shark Nose parts come back from paint. Does the speaker wrap used to bring out more bass from the speakers make a significant difference in the sound/clarity of the bass sound??
Jimmy O.
100th Anniversary Glide
No Ride like a Low Ride Glide!!
jimmyo79 is offline
post #10 of 29 (permalink) Old 02-14-2011, 04:30 PM Thread Starter
Peewee's Avatar
To me its kinda hard to describe. I tend to say that it tightened the bass up. After the foam was in, and the fairing was back on, it kinda sealed the fairing, forcing the air to come back out through the speaker, and not get "lost" inside the fairing. A more full sound if you will. I don't really know how else to explain it, hopefully someone else will chime in if they have a better way to explain it. But regardless of the explaination.....well worth the bucks. I think it is only about $40 so a pretty cheap mod too!
"Know Thyself"
Peewee is offline
Bazooka MC-HD-AK4 Harley Davidson 4 Channel Motorcycle Audio Kit boomerman Parts for Sale 1 03-28-2013 07:50 AM
Boom Audio/Bazooka Amp Lesson Learned Fahred Audio 3 06-10-2012 11:49 AM
J&M Rokkers with Bazooka Amp PFWiz Road Glide Specific Discussions 2 07-01-2011 08:49 PM
Bazooka MC-HD-AMK 4 Channel Amp? EricFLTRU Road Glide Specific Discussions 4 06-07-2011 02:12 PM
Bazooka Motorcycle Audio System New in Box! double Classifieds Archive (3 months old+) 1 05-23-2011 09:22 PM
