Battery died, now speakers not working!!!!!! - Road Glide Forums
post #1 of 12 (permalink) Old 02-11-2011, 04:47 PM Thread Starter
I have a 2004 RG that was in storage for 6 months. The battery went dead so i put it on the trickel charger over night and now it fires up no problem. The issue i do have is with my radio. All the lights on it work and it will spin a cd how ever nothing comes out of the speakers. i flip the speaker switch back and forth still nothing. Any ideas?? just about to do an upgrade to a sony head unit and some 6 1/2 but not there yet. so far the radio and speakers are stock.
schnid72 is offline
post #2 of 12 (permalink) Old 02-11-2011, 06:17 PM
Admin
BillyBob's Avatar
Could be A fuse??
BillyBob is offline
post #3 of 12 (permalink) Old 02-11-2011, 06:49 PM
Peewee's Avatar
BigDaveOnBass had a similar problem in that only one speaker died. He picked up a used stock headunit from a member and now he has no problems
"Know Thyself"
Peewee is offline
post #4 of 12 (permalink) Old 02-11-2011, 07:05 PM
Sincecrazy's Avatar
That doesnt make much sense. Have you tried disconnecting the battery? Other than that I would remove the speaker switch and see if its working.
Sincecrazy is offline
post #5 of 12 (permalink) Old 02-11-2011, 07:54 PM Thread Starter
The light switch lights up when i switch it on and what not, i know its a wierd thing to have happen. i am thinking the head unit finally died. what do you'll think?
schnid72 is offline
post #6 of 12 (permalink) Old 02-11-2011, 07:55 PM Thread Starter
checked all the fuses also. i will try disconnecting the battery to see if that clears it. post back when its done.
schnid72 is offline
post #7 of 12 (permalink) Old 02-11-2011, 08:09 PM Thread Starter
ok disconnecting the battery did not work. any other ideas?
schnid72 is offline
post #8 of 12 (permalink) Old 02-11-2011, 08:38 PM
Try This
Pull main fuse, disconnect bat, Bring to full charge, connect main fuse then reset all clock and all other functions. good luck
Frodoe is offline
post #9 of 12 (permalink) Old 02-12-2011, 05:23 AM
Peewee's Avatar
I'm thinking your head unit has given up the fight. However, you might want to pm BigDaveOnBass. He might have some suggestions for you to check seeing how he had a similar issue.
"Know Thyself"
Peewee is offline
post #10 of 12 (permalink) Old 02-12-2011, 06:39 AM
Sincecrazy's Avatar
Sounds like your going to have to remove the outer fairing to check wiring and speakers. So either the mute function is on, the speaker switch doesnt work, or the radio has lost output function, unless the speakers are bad. Again, there doesnt seem to be much that makes sense with this. Other than that you may want to try ironcross audio for repair, should you decide to retain the factory radio.
Neutral light on cruise not working and gear indicator not showing Xman247 Tools and Garages 7 08-11-2018 11:09 AM
2012 RGU: Coughed, died and now wont turn over vmaxerg Engine Related 8 02-21-2018 11:57 PM
Battery died - less than 200mi on FLHXS rcolemanreed Troubleshooting for Road Glides 2 05-27-2017 10:21 PM
Battery tender leads not working... NCRG12 Troubleshooting for Road Glides 6 08-18-2013 12:10 PM
HEAVY HEAVY rains now speakers are not working well rob883 Audio 6 06-18-2013 01:32 PM
