Radio Upgrade? - Road Glide Forums
post #1 of 4 (permalink) Old 03-10-2011, 09:28 AM
Ironbyron58
Guest
Posts: n/a
Radio Upgrade?
Will a 2006 or newer OEM radio work in my 03 Roadglide?
Will I have to change the speakers to 2 ohm? vs 8 ohm?
post #2 of 4 (permalink) Old 03-10-2011, 12:22 PM
Peewee's Avatar
The short answer is no. Wiring harness is different. The long answer would be with a lot of work, patience,and electrical manuals.....maybe. If you were to be able to swap, you would also need to change speakers. Probably be better to go with an aftermarket upgrade. Plenty have had experience with this, and I know they will chime in and help. Which is one reason why I love this place!
"Know Thyself"
Peewee is offline
post #3 of 4 (permalink) Old 03-10-2011, 12:48 PM
you could make it work by doing wiring and changing speakers.
JMO I would opt for an aftermarket radio, bigger amp, better sound,
USB port for MP3 etc
Check here for some options, but do some research there are several
options
http://www.eglidegoodies.com/id179.html
"My rule of life prescribed as an absolutely sacred rite smoking cigars and also the drinking of alcohol before, after and if need be during all meals and in the intervals between them." Winston Churchill
Hotroadking is offline
post #4 of 4 (permalink) Old 03-10-2011, 01:24 PM
Ironbyron58
Guest
Posts: n/a
Thanks that is the answer I came up with but wanted to be sure.
Aftermarket would be best in my case.
15/16 RG radio upgrade ??? 93-331-29psi Audio 3 09-11-2015 10:00 AM
2013 Road Glide CVO Radio Upgrade electric arc Audio 12 07-02-2015 02:32 PM
Radio upgrade Questions Lunchboxx Audio 4 01-25-2015 07:39 AM
My $7 dollar radio upgrade holdover skipper Audio 9 10-05-2013 06:33 PM
Sony Radio Upgrade fern5407 Equipment-RG 4 03-22-2013 03:16 PM
