How to wire an amp - Road Glide Forums
post #1 of 7 (permalink) Old 03-23-2011, 01:50 PM Thread Starter
How to wire an amp
Got an amp 4 channels it has both RCA plugs and straight twisted pair connections, however instead of single - channel plugs for each channel
it has shared N plug in. It's a three wire with +1 - +2 on the connector
Should I use a line converter (more money, more parts, more space needed)
or convert the twisted pair to RCA
Or would it be advisable to use the three wire and join the N lines from 1 and 2 together as they hit the amp..
BTW the new 4 channel ARC has only RCA inputs so thats going to be an issue anyway
"My rule of life prescribed as an absolutely sacred rite smoking cigars and also the drinking of alcohol before, after and if need be during all meals and in the intervals between them." Winston Churchill
Hotroadking is offline
post #2 of 7 (permalink) Old 03-23-2011, 08:44 PM
sportyguy69's Avatar
Wow I dont have a clue, did you write that in English? .....lol
If your going to do something give it all you got, might be the last time you ever do it !!!
sportyguy69 is offline
post #3 of 7 (permalink) Old 03-23-2011, 08:54 PM
can u take a picture of it
bosshogg is offline
post #4 of 7 (permalink) Old 03-24-2011, 07:36 AM
Carisma Audio's Avatar
I would suggest using a line level convertor they are about 20 dollars and will be well worth the money to make your amp install correct and perform properly if you need more help just pm me thanks
Carisma Audio is offline
post #5 of 7 (permalink) Old 03-24-2011, 08:44 AM
MassHD's Avatar
Carisma I have the 2 channel arc amp. Is moding the HK unit with RCA out worth it or should I leave my head unit alone?
2010 Road Glide Denim Black
ABS Cruise Factory Security, Black D&D 2 into 1
Firecap's Arc Amp 125.2, 4- Hertz 6 1/2" Speakers
PYO Bars, CVO Rear Fender, KW Wrapper Front Fender
"Burn Rubber Not Your Soul"
MassHD is offline
post #6 of 7 (permalink) Old 03-24-2011, 12:23 PM
If you have no issues with your install keep it that way. It would only make a difference if you had installed a aftermarket head unit with high power outs on the rca's
post #7 of 7 (permalink) Old 03-24-2011, 03:21 PM
MassHD's Avatar
Thanks might change the head down the road.Need to finish my current mods.
MassHD is offline
AMP Install Power & Ground Wire Routing wevsspot Audio 4 05-08-2015 09:27 AM
J&M Amp Ground Wire Help tsmartt Audio 6 05-29-2014 01:32 PM
Looking for wire & cable advise mfkb1 Controls & Handlebars 5 08-26-2013 01:24 AM
Read at my post Hawg Wire deals om new amp DragoBikeWorks Audio 6 01-12-2013 07:57 AM
Amp install - where to splice the turn on wire? modot66 Audio 3 12-09-2011 01:06 PM
