Installing a KS125.2 mini - Road Glide Forums
post #1 of 41 (permalink) Old 03-25-2011, 05:24 PM Thread Starter
Wildman's Avatar
My wife gave me a Arc amp for my birthday. It will be here next week so I am looking for instructions on how to install this amp. Has anyone here used one of these amps? I am wondering if I should get the install kit that Arc offers.
I am already using J&M 7.25 speakers so I am really looking forward to hearing how this will sound now.
WILDMAN
1997 Jeep TJ SE
2011 FLTRU Road Glide Ultra
2009 Buell XB12R Firebolt
2008 Honda TRX700XX
Wildman is offline
post #2 of 41 (permalink) Old 03-25-2011, 06:25 PM
Donk's Avatar
I can give you a quick run down....
Buy a 8 guage amp wiring kit. Run the 8 guage fused power wire from battery, under the tank to inner fairing. Take outer fairing off. You can mount the amp on top of the radio with velcro if you wish, or you can mount it beside the glove box on the inner faring. There are alot of options for mounting. Then run a 8 guage ground wire to something close to the amp inside the fairing if you can. I heard some people using the frame bolts to the fairing, some use the highway bar bolts... Just find a good ground. Then disconnect the wires from your J&m's, run the speaker wires to the high level inputs on the amp, and then run new speaker wire from the amp to the J&m's. Turn the AVC off or less than two bars. Set your EQ to zero, turn the gain all the way down, set the crossover on the amp to full range. Turn the volume up to 3/4. Use a test cd and play a solid 50hz tone.... turn the gain up untill it distorts , then turn it down jut a little. And your ready to go.
Or you can do the more accurate way of tunning the amp. Take your RMS wattage for one channel on your amp (125 watts) multiply that by the ohm's your speakers are wired to (2ohms) which in your case will equal = 250. Take the square root of that number (sqrt of 250= 15.81). Now take a volt meter or O-scope if your lucky enough to have one. Disconnect your speaker output and place the voltmeter cross one channel + and -. Play the 50hz test tone. Turn your gain up untill you have a voltage reading of 15.81. Then do the same for the other channel.
Hope this helps. Sorry I didnt have much time to do more detaails.
Donk is offline
post #3 of 41 (permalink) Old 03-25-2011, 08:16 PM Thread Starter
Wildman's Avatar
Donk,
That was a great post thank you a lot. Of course I just got done ordering Arc's install kit and it only has a 12 gauge power wire. O'well I'll just get a different power cable.
Again thanks for a great post.
WILDMAN
1997 Jeep TJ SE
2008 Honda TRX700XX
Wildman is offline
post #4 of 41 (permalink) Old 03-25-2011, 08:34 PM
Donk's Avatar
12 guage will work fine. IM an overacheiver when it comess to audio so I would go with guage persoanlly. 12 should be ok. Good luck with your install.
Donk is offline
post #5 of 41 (permalink) Old 03-25-2011, 08:51 PM Thread Starter
Wildman's Avatar
Donk,
How do I get the 50Hz test tone? Is this from a special CD or something?
Thanks again. I just bought a 8 gauge kit too, I'll just send the ARc one back.
WILDMAN
1997 Jeep TJ SE
2008 Honda TRX700XX
Wildman is offline
post #6 of 41 (permalink) Old 03-25-2011, 08:53 PM
abone's Avatar
Send a message via Yahoo to abone
Donk, do you recommend the BX (bass enhanced) version of this amp?
2010 RG
abone is offline
post #7 of 41 (permalink) Old 03-25-2011, 08:55 PM
MassHD's Avatar
The other thing is that amp will not fit on your radio. For our RG you need to put it in between the inner fairing and the glove box. I super velcro'ed it and it has never moved one inch.
2010 Road Glide Denim Black
ABS Cruise Factory Security, Black D&D 2 into 1
Firecap's Arc Amp 125.2, 4- Hertz 6 1/2" Speakers
PYO Bars, CVO Rear Fender, KW Wrapper Front Fender
"Burn Rubber Not Your Soul"
MassHD is offline
post #8 of 41 (permalink) Old 03-25-2011, 09:00 PM
abone's Avatar
Does it matter what side of the fairing you mount it?
2010 RG
abone is offline
post #9 of 41 (permalink) Old 03-25-2011, 09:10 PM Thread Starter
Wildman's Avatar
MassHD thanks for the tip.
Abone, I am getting the BX amp but I don't know how much of a differance there is between the two of them.
I am looking forward to putting this in my bike.
WILDMAN
1997 Jeep TJ SE
2008 Honda TRX700XX
Wildman is offline
post #10 of 41 (permalink) Old 03-25-2011, 09:53 PM
MassHD's Avatar
Just happen to have my fairing off.
MassHD is offline
Arc audio ks125.4 $225 Zunman Parts for Sale 3 01-17-2017 01:09 PM
ks125.4 Mount Deadstroke Audio 1 02-20-2015 11:09 AM
Elf audio e2125x mini amplifier arc ks125.2 micro amp jimmyray11349 Audio 2 07-20-2011 10:48 AM
My Custom Handlebars (BR Custom Cycles mini apes) should be here today! The Infamous Sharknose Controls & Handlebars 9 04-20-2010 05:16 PM
OK...Lets try this again. Updated Pics of my new Mini apes The Infamous Sharknose Controls & Handlebars 41 11-05-2009 02:52 PM
