I need help with 6.5 speaker adapters... - Road Glide Forums
post #1 of 23 (permalink) Old 04-02-2011, 12:51 AM Thread Starter
RIDERED67's Avatar
I bought a set of 6.5 speaker adapters from YAFFE (made by dragonfly). The adapters came with terrible instructions and the included pictures are too dark to see correctly. I also noticed that the directions seem to be for a batwing. Anyway.... I cant get these the adapters to fit! I played with them for over an hour flipping them every which way and i cant figure them out.
Anybody have any suggestions or pictures of installed adapters?
Could YAFFE have given me batwing adapters by mistake or are they all the same?
I know it should be simple but i feel like im trying to put a round peg in a square hole
Thanks!
2011 Denim Black Roadglide
RIDERED67 is offline
post #2 of 23 (permalink) Old 04-02-2011, 07:19 AM
Carisma Audio's Avatar
The small side goes towards the factory grill but you will need to modify the factory grill mounting spots by making the area at the 3 mounting screws smaller then they will it properly. they are the same ones for the street glide and not made from dragon fly hope this helps
Carisma Audio is offline
post #3 of 23 (permalink) Old 04-02-2011, 01:06 PM Thread Starter
RIDERED67's Avatar
Thanks for the reply. Im still having some trouble understanding...
Do i reuse the entire factory "speaker pod" to include the mesh grill and the original plastic speaker mount or should i peel the mesh grill off and trash the factory plastic?
Thanks for the help
post #4 of 23 (permalink) Old 04-03-2011, 07:13 AM
The factory grill and speaker mounting plate stay intact and the new adapter mounts to that.
post #5 of 23 (permalink) Old 04-15-2011, 08:35 PM
gja
You have to modify the adaptors to fit the grills. There are fins on the adaptors that need to be snipped off to make them fit. I used a dremel to grind down the fins.
Call Dragonfly and they will send you a copy of the instructions.
gja is offline
post #6 of 23 (permalink) Old 04-21-2011, 09:02 AM
Not impressed w/ Dragonfly stuff...
FYI...Dragonfly's adapters are $hitty. The Focal 6-1/2" speakers don't fit completely inside...hampering the speaker's ability to move correctly for best sound quality and performance. If I had it to do all over again, I would have gone with another set of adapters...and likely a completely different system altogether.
I'm underwhelmed to say the least....I got caught up in all the hype...my bad I guess.
DaFrankster is offline
post #7 of 23 (permalink) Old 04-24-2011, 06:53 AM
The adapters I have had no issues installimg them they fit well, but I do add material to make the adapters resonate less so there are no frequences cancelled out and then grind a small amount of material from the adapters then, if I have cone clearence problems I modify the adapters so all is perfect.
post #8 of 23 (permalink) Old 04-24-2011, 07:37 AM Thread Starter
RIDERED67's Avatar
I agree that these adapters are sh*t!! I finally got the adapters and the 6.5 rockfords installed but when I tried to put the outer fairing back on it was hitting the speaker magnets on both sides. I most likely could have tried repositioning the adapters but it would have been a huge pita. I pulled the whole setup and order some JM 7.25's. Thanks Yaffe! Terrible instructions and cheap plastic adapters that didnt work after I had to make them fit
post #9 of 23 (permalink) Old 05-02-2011, 09:27 PM
Dragonfly adapters
Carisma, Wondering if you took a pic of the install. I also got sent the poor directions from yaffe. Having a problem on exactly how to mount/remove material if needed. BTW what material do you use for resonance and where does it get installed? Thanks.
Mac Daddy Glide is offline
post #10 of 23 (permalink) Old 05-02-2011, 09:42 PM
Should bolt up maybe clip a fin or two to help rotate. Here are the only pictures I had
"My rule of life prescribed as an absolutely sacred rite smoking cigars and also the drinking of alcohol before, after and if need be during all meals and in the intervals between them." Winston Churchill
Hotroadking is offline
Speaker Adapters Willy_B Audio 10 04-15-2012 09:10 AM
Has anyone used these speaker adapters??? HDFFR Audio 2 03-11-2012 10:10 PM
speaker adapters spender9 Audio 2 05-10-2011 06:26 PM
rca to line level adapters need help please manbug50 Audio 3 05-10-2011 06:22 PM
speaker adapters gja Aftermarket Accessories 6 03-30-2011 08:45 PM
