2010 ACC switch - Road Glide Forums
post #1 of 3 (permalink) Old 04-05-2011, 09:50 AM Thread Starter
h-donut's Avatar
2010 ACC switch
what does this turn on?
the light comes on but nothing happens....
I would like to find out where the output of this switch is so I can use it to turn
on and off an audio power amp.
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #2 of 3 (permalink) Old 04-05-2011, 10:01 AM
I believe it's under the seat, 4 pin connector
Does your amp have three inputs for power,
Pos - Direct from battery fused line
Neg - Ground to frame
Switched Power - Turn on power
The switched power can be a wire coming off an Orange wire with white stripe, this is switched power, run it over to that connector, when the bike powers on the amp will power on automatically.
You don't need that switch unless you have some specific reason you'd want to kill the amp, which will kill all tunes...
"My rule of life prescribed as an absolutely sacred rite smoking cigars and also the drinking of alcohol before, after and if need be during all meals and in the intervals between them." Winston Churchill
Hotroadking is offline
post #3 of 3 (permalink) Old 04-05-2011, 10:21 AM Thread Starter
h-donut's Avatar
okay, thanks, yeah switching the amp is overkill.
h-donut is offline
ACC Switch and USB PLug hinerj Do-IT-Yourself 33 07-03-2014 08:43 AM
Muting the radio- ACC Switch Puff-N-Stuff Tech Area 20 04-05-2013 11:07 PM
Checking if acc switch was connected at moco jacksonfdny *General Road Glide Discussions/Pictures 10 10-02-2012 06:26 AM
My ACC switch does't work ????? jacksonfdny *General Road Glide Discussions/Pictures 2 09-30-2012 12:41 PM
ACC switch question ODA CDR (RET) Controls & Handlebars 3 05-24-2012 06:40 AM
