Looking for rear speaker wires harness - Road Glide Forums
post #1 of 3 (permalink) Old 04-19-2011, 12:55 PM Thread Starter
Is there a harness under the seat or under the side covers that are for the rear speakers? I imagine if you wanted to add a tour pack with speakers, Harley would make it easy to plug right in.
I was hoping to tap into that harness to get high level speaker inputs from the HK radio to the amp going into my saddlebag.
If not then I would have to run speaker wires from the HK radio to the amp for high level speaker inputs.
Thanks,
ddaarr is offline
post #2 of 3 (permalink) Old 04-19-2011, 01:52 PM
Shrug's Avatar
I had to run my own for my hog tunes amp. I suspect unless you have a RGU, there aren't any extra speaker wires.
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #3 of 3 (permalink) Old 04-19-2011, 02:09 PM
RoadGlideRider's Avatar
The harness for just the rear speakers and switches is 77157-06.
You will need the Non-Ultra Harness (70169-06) to have a way to plug the speakers into the radio. This harness also gives you the opinion to be able to plug in other radio accessories at a later time. It make it just a Plug and Play.
Or if you are good at electronics, you can just get your own plug and install you own plug.
I didn't choose to go that way. I have the Factory Harness. This keeps the wiring Factory and if or when I sell, it makes the sale easier.
Just don't forget, if you use the H/K Rear speakers, you will need to get the Fader control program installed in the radio. Do a search and this Fader Program is talked about.
RoadGlideRider is offline
16 RGS rear speaker harness color code HD2fly Audio 3 07-18-2017 07:05 AM
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 10:17 AM
Hawg Wired Rear Speaker Breakout Harness Orangeappeal Audio 0 02-19-2015 09:04 PM
need a little help finding my rear speaker wires mroach Audio 3 03-18-2012 08:30 AM
WTB Rear Speaker Harness Part # 77157-06 rmack888 Classifieds Archive (3 months old+) 4 06-02-2011 02:42 PM
