Hawgwired ZX's static and buzz at low volume - Road Glide Forums
post #1 of 6 (permalink) Old 08-23-2013, 04:41 PM Thread Starter
RGUrider's Avatar
Got a problem that just started today, right side HW ZX sounds like static or buzz at low to zero volume. Seems to play just fine, so I haven't blown it. Setup is Sony HU, biketronics bar control adapter (speakers do not run through it, amp wired directly to HU), RF PBR300x2 driving the HW and a set of pioneers. Speakers are 4ohm, 200-250 watt. HU is 3 months old, rest are about 8 months.
Any thoughts on what it may be or how to go about troubleshooting are much appreciated.
RGUrider is offline
post #2 of 6 (permalink) Old 08-23-2013, 05:30 PM
Do you have Daymakers or any other LED lighting? I noticed LED lighting can sometimes introduce a hum, which can be solved sometimes by rerouting wires, I solved mine by installing a filter.
post #3 of 6 (permalink) Old 08-23-2013, 05:42 PM
Brewiz's Avatar
I had the same problem, it turned out to be a bad RCA cable.
Brewiz is offline
post #4 of 6 (permalink) Old 08-24-2013, 08:26 AM Thread Starter
RGUrider's Avatar
Stock lighting. Appreciate the input. SInce its still working I am riding, hell if it went out I would still choose to ride. Rode for 40 some years without tunes. I'll tear it down and check wiring some rainy or cold day.
RGUrider is offline
post #5 of 6 (permalink) Old 08-24-2013, 08:59 AM
Neano62's Avatar
Ground Issue,....
or a Cable not plugged in all the way, bad, or touching another cable 'End' somewhere.
I'd 'Start' with all grounds.Even if ya hook a meter up to m, and it says its strong, find another point to ground. Stick with, if ya already havnt, the directions say to ground.
[/IMG]
Neano62 is offline
post #6 of 6 (permalink) Old 08-24-2013, 11:38 AM
pat123's Avatar
I had the same problem. I fixed it by using the high inputs instead of the RCA cables. It fixed all the noise. When I called hawg wired about another issue I asked them about it and they said its common with led lights. They said using the high inputs fixes the issue.
pat123 is offline
Static at mute and low volume Exrpnt Audio 14 07-21-2017 09:05 PM
Static at mute and low volume Exrpnt Audio 0 07-10-2017 11:03 AM
Static at mute and low volume Exrpnt Audio 0 07-08-2017 05:42 PM
Buzz coming through aux port with NIM, Bomm, and Roadtech 665 pryda GPS 3 03-15-2014 02:15 PM
hawgwired zx 6.5 come in red? Fleshwound Audio 5 10-10-2012 06:30 PM
