Speaker Polarity ***Help*** - Road Glide Forums
post #1 of 7 (permalink) Old 08-24-2013, 04:57 PM Thread Starter
MakeARunMike's Avatar
I re-did some wiring inside the fairing today ang somehow got my radio output wires crossed. I have a stock HK head, and a RF PBR300x4 amp. I have 2 Polk DXI 650's in the inner and 2 Polk 6500's components in the upper. I need help figuring out which are the (+) and (-) HK radio outputs to feed into my amp. The two wires on the right side are grey/red and light green/black. The two on the left side are white/orange and light green/white.
Just lookin' for a little more chrome and a little more rumble...
10" Monkey Bars
ThunderMax ECM
Arlen Ness Big Sucker
Vance & Hines Dresser Duals
Klock Werks SS Slash Up
4-Speaker Set Up w/ Amp
Chopped Tour Pak
Other Chrome Doo Dads
MakeARunMike is offline
post #2 of 7 (permalink) Old 08-24-2013, 06:10 PM
DC-3Mek's Avatar
Not at the house right now so can't look it.
Do you not have the ends of the wires (connectors)?
They are different sizes so I you have the old speakers you can either look at the male connectors on the speakers and go from there.
Or if you have a volt ohm meter, just put it on the wires coming out the radio and at low output check the polarity. If the output is positive you have the correct polarity. In other words the red wire is the positive output of the radio
Ride more.......post less........................~
DC-3Mek is offline
post #3 of 7 (permalink) Old 08-24-2013, 06:44 PM Thread Starter
I do not have the old connectors. I had hooked to the connectors that the speaker connector plugged to. I will check it with my volt meter. Still let me know what you find out. Thanks
10" Monkey Bars
ThunderMax ECM
Chopped Tour Pak
post #4 of 7 (permalink) Old 08-24-2013, 06:55 PM
DC-3Mek's Avatar
Drinking beer right now at the local watering hole, but if you have a volt meter you're golden!
It's real easy to figure out. If you wanna make sure of what you are seeing, just reverse the leads on the wires and the polarity on the distal readout will go to brag active. Just put a piece of tape on the positive or write it down. Like I said, I have the manual, but I still checked it with my meter. That's the cocksure way to know!!! LOL!!!
BTW, you'll love that amp!!!
DC-3Mek is offline
post #5 of 7 (permalink) Old 08-24-2013, 06:57 PM
DC-3Mek's Avatar
"BRAG ACTIVE"!!!????
WTF!!!???
LOL!!!
THAT should have been "back and forth to positive/negative"!!!!
DC-3Mek is offline
post #6 of 7 (permalink) Old 08-24-2013, 07:40 PM
JacktheBagger's Avatar
adult beverages + keyboard + a child =
JtB
2011 Ultra
JacktheBagger is online now
post #7 of 7 (permalink) Old 08-24-2013, 11:43 PM Thread Starter
Thanks for the go-ahead on the volt meter. Will do it at first daylight. Sounds like a winner.
10" Monkey Bars
ThunderMax ECM
Chopped Tour Pak
Lower Fairing Speaker pods: How did you guys run the speaker wire? Slider57 Audio 3 02-10-2018 03:12 PM
Speaker lid speaker help Heavy Metal Audio 7 10-27-2017 03:07 AM
6"x9" speaker kit that fits HD speaker lids JuicedHD Audio 1 01-18-2013 06:19 PM
I need help with 6.5 speaker adapters... RIDERED67 Audio 22 09-20-2012 10:43 PM
speaker help cjdroadglide *General Road Glide Discussions/Pictures 14 02-28-2011 02:08 PM
