Any advice on install of RF PBR300X2? - Road Glide Forums
post #1 of 3 (permalink) Old 09-01-2013, 06:30 PM Thread Starter
Ok guys, am going to attempt to install the RF amp on my 2012 Shark. I am not very savvy at this type thing. I am pretty good at doing things myself, but also, am smart enough to ask for advice and help on things that others have done before. Am going to get a bracket from H-Donut, but as far as the wiring process, is there any pointers that you guys can give me?
Hammerjsr20 is offline
post #2 of 3 (permalink) Old 09-01-2013, 08:12 PM
There is a lot of info in the DIY section in audio. I can tell you if your using the stock HK, make sure you wire to the high side on the input, follow the instructions, if you have any questions while doing the install there are plenty of people here including myself who will offer advise and answer questions. What speakers are you going with?
post #3 of 3 (permalink) Old 09-01-2013, 08:49 PM
h-donut's Avatar
hawg wired has a great wiring tutorial on their site
recommend using 8ga wiring kit over thinner cheaper 10ga kits
and the loudest speakers you can afford
2010 FLTRX- r o a d g l i d e
h-donut is offline
RF PBR300x2 advice Hamrhead Audio 5 03-27-2017 08:08 PM
2015 dual RF PBR300X2 amp install. Cjlianzo Audio 0 07-06-2015 07:58 PM
Mounting RF PBR300X2 Magnum Audio 13 05-10-2014 09:49 AM
RF Punch PBR300x2 Liquidr1 Audio 10 02-12-2014 10:08 PM
Where to Buy RF PBR300X2? gfyoung3 Audio 15 04-27-2013 03:58 PM
