Battery dead after amp install - Road Glide Forums
post #1 of 13 (permalink) Old 09-04-2013, 07:32 AM Thread Starter
I have recently installed a Rockford Fosgate amp and four 6.5 inch polk speakers. The bike ran fine for about a week after install but towards the end of last week it it began to become harder to start. I park it Friday went away for the weekend and attempted to start it this morning. The bike was not on a battery tender since I figured it was only going to be sitting for 4 days.
The amp has a power wire running directly to the battery with an inline fuse. The speakers are soldered in to the supplied fosgate connectors and connected directly into the amplifier. From what I've read as long as the speaker wires are connected to the amplifier directly I did not need to run the remote wire to shut the amp on and off.
What am I missing here?
infernomd is offline
post #2 of 13 (permalink) Old 09-04-2013, 07:53 AM
I had the same problem once. Turn up the sensitivity on the amp, I guarantee you the amp is not shutting off, and that is killing you battery.
Sent from my SPH-L710
post #3 of 13 (permalink) Old 09-04-2013, 08:54 AM Thread Starter
How do you turn up the sensitivity on the amp? I was going to splice into the main power line and install a cutoff switch. Just need to remember to turn it off when I park the bike.
post #4 of 13 (permalink) Old 09-04-2013, 08:56 AM
DED HD's Avatar
Make sure you have a the amp properly grounded- Same happened to me with my J&M amp, and i "thought" i had a good ground, but i didn't.
'10 Red Custom:
DED HD is offline
post #5 of 13 (permalink) Old 09-04-2013, 10:12 AM Thread Starter
As far as grounding I ran the ground back to the negative on the battery per Rockford fosgate specs on their knowledge base. If the amp is functioning properly how can I test the ground?
post #6 of 13 (permalink) Old 09-04-2013, 10:21 AM
OKBigD's Avatar
Go here..
http://www.rockfordfosgate.com/suppo...ew=1#knowledge
page 8 Variable High Level Adjustment.. I agree with Dbell your amp probably isn't turning off....
OKBigD is offline
post #7 of 13 (permalink) Old 09-04-2013, 10:22 AM
garvin90's Avatar
That's not grounding it. Ground and negative aren't exactly the same thing. Find a bolt that goes directly to the frame and connect your ground that way.
Sent from the roadglide.org Monarch's phone
2012 Chrome Yella!
garvin90 is offline
post #8 of 13 (permalink) Old 09-04-2013, 10:33 AM Thread Starter
I am just trying to understand here. The amp will still function even though it may not be grounded properly? By changing the location of the ground to the bike frame will allow the amp to power itself off? This was the article from fosgate that I followed.
post #9 of 13 (permalink) Old 09-04-2013, 10:42 AM
DED HD's Avatar
well i have a different amp so i cant speak from experience with the Rockford amp, but the J&M amp ground wire, is grounded to where the negative battery cable grounds- in front of the battery on the master frame grounding stud.
'10 Red Custom:
DED HD is offline
post #10 of 13 (permalink) Old 09-04-2013, 10:53 AM Thread Starter
I will try swapping the ground location and will also check the Variable High Level Adjustment on the amp itself. I read throught the section on that adjustment but need more information on that. By adjusting the setting between 4v and 6v does it actually delay the amp turning on and off?
Thank you eveyone for the input so far.
Battery Draining after stereo/amp install soup22 Audio 8 03-03-2016 09:59 AM
Battery going dead LittleMoe Troubleshooting for Road Glides 8 05-23-2015 09:33 AM
Dead fob battery bambamortiz Tech Area 20 05-30-2013 09:42 PM
Consequences of long dead battery? carcass *General Road Glide Discussions/Pictures 7 01-08-2013 08:48 PM
Now battery is dead a month after installing J&M amp DED HD Audio 4 06-30-2011 01:28 PM
