Harley XM radio missing channels ?????? - Road Glide Forums
post #1 of 5 (permalink) Old 09-07-2013, 04:23 PM Thread Starter
KanGlide13's Avatar
For a clean look I went with the 76404-06 Boom! audio XM radio add on. But I have found out that all of the channels I am supposed to get, don't show up on my radio for some reason. For example one of my favortie stations is OutLaw Country on channel 60, but it jump from 59 to 64 (i think). Too mad to remember exactly. But doesn't really matter. There are other "blocks" of channels that don't show up either. My thing is I didn't drop $700 installed cost for a limited channel lineup. I called XMSirius to verify my subscription and channel lineup, which is the same as our other sat radio that has the same lineup. My next call was to my dealer. They didn't have an answer but said they would call the MOCO on Tuesday (not open Monday) and let me know what the solution is. I did let them know that my expectation was a FULL channel lineup out of this unit and they assured me they understood. So if this is a limitation of the Harley/HK/Boom unit I will be expecting a full parts and labor refund. Anyone else had this missing channels issue with Boom XM?
KanGlide13 is offline
post #2 of 5 (permalink) Old 09-07-2013, 05:01 PM
It sounds like the radio is not registered properly. Currently XM is running 60 channels for free until Sept 9. If it completely stops on the 10th you will know it is the radio registration with XM as the problem.
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
post #3 of 5 (permalink) Old 09-07-2013, 05:22 PM Thread Starter
KanGlide13's Avatar
thanks
Yep, that was it. Apparently I was getting the "free trail" channels, which is almost all the music channels. I rolled the bike outside, turned it to channel 1, logged onto our Sirius/XM account and resent the sync signal. Its all good now. Thanks for the tip AzHogRider.
post #4 of 5 (permalink) Old 09-07-2013, 07:05 PM
skratch's Avatar
what? and all that righteous anger directed at the dealer was wasted?
glad you got it fixed.
skratch is online now
post #5 of 5 (permalink) Old 09-07-2013, 07:15 PM Thread Starter
KanGlide13's Avatar
what anger?
I assure you there was no anger express in my call to my dealer. And I didn't think I stated that in my post either. I did outline my situtation and expectation of the resolution to which the dealer agreed. Sorry if the wording was misleading.
Changing preset channels TimmyG Audio 3 08-19-2014 09:01 AM
How many amps/speakers on the front channels? 09Sharknose Audio 3 05-24-2013 10:21 AM
Using unused 2 channels on radio Easyryder01 Aftermarket Accessories 3 06-18-2012 08:28 AM
Programming rear channels of head unit Sim Audio 1 03-03-2011 11:38 PM
