WTF Have I Gotten Myself Into - Road Glide Forums
post #1 of 19 (permalink) Old 09-11-2013, 10:27 PM Thread Starter
The Volusianator's Avatar
Well, I have had the bike for 15 days now, how the hell long should I keep it stock?
Wade
The Volusianator is offline
post #2 of 19 (permalink) Old 09-11-2013, 10:46 PM
911Shark's Avatar
And the journey begins
2015 CVO/SEPRT/Arlen Ness Big AC/NO Cats/nada mas
2004 SE 103"/Branch P&P heads/Branch 595 Cams/Diamond Cut/SE 6speed/SERT/2n1 Ceramic ThunderHeader/Progressive Monotube F, 444 R
911Shark is offline
post #3 of 19 (permalink) Old 09-11-2013, 10:47 PM
zemo1017's Avatar
Looks like the modification vaccine did not work on you! LOL.
Looking forward to how this turns out.
Plenty on ideas to drain your bank account can be found here.
zemo1017 is offline
post #4 of 19 (permalink) Old 09-11-2013, 10:54 PM Thread Starter
Does anybody know the item number of the Walmart wiring harness?
Wade
post #5 of 19 (permalink) Old 09-11-2013, 10:54 PM
Being in WI I think you would have tried to wait at least until the end of October, unless you get it back together soon you're going to miss the rest of the riding season. But I guess if the bug bites hard you have to do what you want to do.
Sent from my SPH-L710
post #6 of 19 (permalink) Old 09-11-2013, 11:01 PM Thread Starter
Summer in WI goes from June 15th to Aug 1st, so it's over. Hopefully I'll have it back up and running on Saturday.
post #7 of 19 (permalink) Old 09-11-2013, 11:17 PM Thread Starter
A few pics from what I did tonight. I had to shave off the pilliars of the stock speaker grills for the adapters to fit flush, an angle grinder worked well for this and made quick work of the job.
For the speakers in the inner fairing, I went to Microsoft Word and made a template for my speakers, 5.05" hole and 6.85" grill diameter. I made cross hairs over the template to line them up exactly the same on both sides, then taped them in place. Using the smallest drill bit I had, I drilled a hole in the center and then one at 12, 3, 6 & 9 o clock for reference. I removed the template and used a compass to draw a perfect circle, drilled a starter hole and then simply used a jig saw to cut the holes.
Now I just need to figure out the wiring harness, not sure what it's all about but I'm still doing research on that.
Here's some pics, the inner fairing isn't that beat up, it's just dusty.
Wade
post #8 of 19 (permalink) Old 09-11-2013, 11:18 PM Thread Starter
post #9 of 19 (permalink) Old 09-12-2013, 06:09 AM
mmfinn's Avatar
Looking good so far. What took you so long to start making mods?
mmfinn is offline
post #10 of 19 (permalink) Old 09-12-2013, 08:35 AM
MShell's Avatar
I told you once you started you wouldn't be able to stop
Lug nut rule, the one with the most lug nuts wins
MShell is offline
2017's have a slipper clutch!?!?! No more engine braking !?!?! WTF!?!? Spazz *General Road Glide Discussions/Pictures 41 11-22-2016 02:43 PM
Ever Have One of Those, "WTF Just Happened" Moments? SteadyEddie General Off-Topic Discussions 10 08-21-2016 04:56 PM
Allow myself to introduce..........myself Lifetimelifter New Members Welcome Area 46 04-01-2012 10:23 AM
