OEM Harmon Kardon weather seal - Road Glide Forums
post #1 of 2 (permalink) Old 09-16-2013, 08:25 PM Thread Starter
gscojo's Avatar
Anyone have any tips on reinstalling the head unit and getting the weather seal in properly?
Thanks in advance<
Gary
'08, 103ci, Kuryakyn TC2 cams, SERT tuned on dyno, HD Premium Oil Cooler, Jackpot slip-ons, Ricor with Racetech springs in forks, Progressive 412's
Road King bars (modified), Heated Grips, Mustang Saddle, Trunk, Lowers with Classic vents, Madstad.
gscojo is offline
post #2 of 2 (permalink) Old 09-18-2013, 06:36 PM
Its Not Fun However
Here is what I did when I replaced my inner. Clean the old glue off the gasket seal and the radio and then clean with rubbing alcohol. Reseal the Gasket seal on the radio using Permatex RTV Silicone Adhesive Sealant. (Get the Corners!) Let set over night. Use a coat of dish soap on the rim of the inner where the radio is at and some on the gasket itself. Not Much. Insert the radio at a slight angle, top first and let the bottom slide in. The corners are a bitch as they are tight. I slid mine in farther than its suppose to go to make sure the gasket seal was still on the radio correctly and Then slide back to bolt it in. Again it wasn't easy but this worked. You'll have some suds around the radio the first time you wash it too. Good Luck!
lhdcarl is offline
If the weather seal does not seal, what is the point?? Govdog76 Aftermarket Accessories 3 02-21-2012 08:48 AM
Harmon Kardon Warranty jimmyray11349 Audio 3 12-19-2011 05:49 AM
looking for harmon kardon assistance skratch *General Road Glide Discussions/Pictures 0 07-13-2011 08:50 PM
Advanced Harmon Kardon 2009 Neano62 Classifieds Archive (3 months old+) 1 03-16-2011 07:03 AM
Harmon Kardon Stereo and speakers baggerz Classifieds Archive (3 months old+) 0 03-04-2011 10:55 AM
