cb antenna location - Road Glide Forums
post #1 of 4 (permalink) Old 09-18-2013, 08:48 AM Thread Starter
snarley53's Avatar
cb antenna location
ok guy's i've seen something on here about this but can't find it again. my question is which side is the cb antenna on. the manual and hd website say's it's on the right side, but when looking at the conectors on the tourpac the right side has a push in connector like car antennas and the left side has a scew on fitting. all of the cb's i had in the 70's always had screw on antenna connections. so which side is cb and which is am/fm. the book say's it's opposite of what i think it should be. give me some help and don't just say look at the connectors i have and that's why i'm asking.
2011 roadglide ultra.2000 93" s&s rigid panhead,
40 ford rat rod pickup
snarley53 is offline
post #2 of 4 (permalink) Old 09-18-2013, 09:59 AM
chromedome's Avatar
yep
Mine looks like yours and functions as the moco describes. if you want to be sure,
just tune the am or fm radio to a weak station and remove each antenna. When the signal goes away that will indicate that the other antenna is the cb .
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #3 of 4 (permalink) Old 09-18-2013, 10:23 AM
Book is correct. CB is on the riders right/brake lever side. AM/FM is riders left/clutch side. Look close at the base of the antenna, most have a tiny "CB" molded on them.
DuraGlide is offline
post #4 of 4 (permalink) Old 09-18-2013, 11:10 AM
lostboy792's Avatar
I had the same concerns as you did. I did some checking and found the previous post is correct on the sides but you would never guess it looking at the connectors
2012 Road Glide Ultra, BBP. Jackpot head pipe, V&H Monster ovals, VIED's DIY rear air ride suspension, Progressive Mono Tubes in the front -1.
lostboy792 is offline
Hidden Antenna Location? CantRider Audio 3 10-16-2017 09:30 PM
OEM GPS Antenna Mounting Location wevsspot GPS 6 08-14-2017 10:58 AM
Fairing internal antenna location cobra206 Do-IT-Yourself 2 07-21-2012 09:15 PM
Hotel Issues - location location location DreamRider ARCHIVES-SWII LeClaire, IA 29 07-11-2012 12:40 PM
XM antenna location ? spender9 Audio 3 06-12-2011 04:26 AM
