RCA jacks on the back of the Harmon Kardon? - Road Glide Forums
post #1 of 13 (permalink) Old 09-18-2013, 09:30 PM Thread Starter
I bought an iron aces mount that came with "Simple Polywire" hookup for an iphone and hooks in to the power and then to the stereo via RCA jacks. Are there RCA jacks in the back of the Harmon Kardon?
Does anyone have this hooked up? If so could you tell me where you hooked the power wires to? Also, do I need to plug the iphone to the iphone jack to charge and the 3.5mm jack to the stereo to hear it?
Drew
HogPro is offline
post #2 of 13 (permalink) Old 09-18-2013, 10:29 PM
The Volusianator's Avatar
No RCA jacks on the back of the stock HK unit
The Volusianator is offline
post #3 of 13 (permalink) Old 09-18-2013, 10:53 PM Thread Starter
So the Isimple is useless with the stock head unit. LOL.
HogPro is offline
post #4 of 13 (permalink) Old 09-18-2013, 11:07 PM
Shark of the Month August 13
SIC_26's Avatar
Think it will work with either the AUX port OR RCA maybe to accommodate different application (kinda universal)
Looks like it pulls power from the under seat plug, has the 30-pin iPhone connector for phone output and either 3.5mm jack or RCAs for radio input
Hardwire Kit Features
CD-quality music from your iPhone / iPod
Browse your music directly from the iPhone / iPod
Battery charging iPhone / iPod models
3.5mm audio cable for connection into the front input of your Harley-Davidson factory stereo system
Allows you to control volume through the bikes hand controls
*The iSimple IS75 Polywire iPhone/iPod Hardwire Kit requires the separate purchase of a Lightning to 30-pin Adapter for use with iPhone 5, iPod Shuffle or other Apple devices that utilize the new Lightning Connector.
SIC_26 is offline
post #5 of 13 (permalink) Old 09-19-2013, 02:13 AM
No RCAs on the HK.
Iron Cross Audio will install f/r pre amp outs in your HK that are female RCAs
I don't know why the unit that you pictured would have RCAs in one end unless you could plug directly into an amp? I would be curious to hear what the manufacturer says they are for.
HeatWave is offline
post #6 of 13 (permalink) Old 09-19-2013, 07:09 AM
runmanpkll's Avatar
Originally Posted by GoneBlack View Post
I used this with my iron aces mount.
the gray connector connects to the accessory plug under your seat. the two jacks on that end I don't use for anything although I guess I could peek them out from under my seat for headphones.?
the 30 pin iphone connector goes in the phone up on the mount and the "L" shaped jack plugs into the aux port on the front of the radio.
looks like this when all plugged in (minus the garmin)
2011 FLTRX Sedona Orange
runmanpkll is offline
post #7 of 13 (permalink) Old 09-19-2013, 08:07 AM Thread Starter
Does the iphone charge due to the 30 pin plug being plugged in?
Drew
HogPro is offline
post #8 of 13 (permalink) Old 09-19-2013, 08:35 AM
Desertwndrr's Avatar
The iPhone charges with the 30 pin and the audio is run through the Aux connector.
PM or call me if you have issues with it.
2019 RGS, 2016 RGS, 2015 RGS
Desertwndrr is offline
post #9 of 13 (permalink) Old 09-19-2013, 12:19 PM
SIC_26's Avatar
Exactly what ^^he said^^
SIC_26 is offline
post #10 of 13 (permalink) Old 09-20-2013, 05:01 AM
Originally Posted by HeatWave View Post
No RCAs on the HK.
ICA can also install an iPod charge and play cable that will eliminate the need to plug into the front aux
racer-x is offline
harmon kardon stereo SGT_Rob Miscellaneous for Sale 5 05-31-2012 09:19 PM
Harmon Kardon Warranty jimmyray11349 Audio 3 12-19-2011 05:49 AM
looking for harmon kardon assistance skratch *General Road Glide Discussions/Pictures 0 07-13-2011 08:50 PM
Advanced Harmon Kardon 2009 Neano62 Classifieds Archive (3 months old+) 1 03-16-2011 07:03 AM
Harmon Kardon Stereo and speakers baggerz Classifieds Archive (3 months old+) 0 03-04-2011 10:55 AM
