Anyone tried the Polk DB6051 in the inner fairing? - Road Glide Forums
post #1 of 6 (permalink) Old 09-19-2013, 10:26 AM Thread Starter
CNMTurner's Avatar
Well.. time to bite the bullet and start cutting. I'm looking for a little more sound and was thinking of adding an addition set of speakers to the inner fairing (Next to forks).
Currently, I have the stock head unit (will replace next), RF3002 amp, and a set of Biketronic Titian II's. I was thinking of adding the Polk DB6501 components to the inner fairing and was wondering if anyone has tried it. My concern is the clearance of the grills and the fork bezel screws.
My thoughts for choosing the 6501's is that they handle power well, sensitivity is good and the crossover should be a little better and I can locate the tweeters either in the gauge holes or mount in the inner fairing in front..
Any thought comments from the Stereo Pros would be appreciated!
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
post #2 of 6 (permalink) Old 09-19-2013, 12:06 PM
zuppy51's Avatar
Yes, I've tried 2 different polks. 651 coax, and 6501, with the seperate cross overs.
Both fell apart after a few months of riding. I went through polk warranty to get them replaced. After dealing with them for 2 go arounds, I decided to switch to the Rockford Fosgate 6.5 Coax T165. I could not be happier...
It's been solid, excellent sound and ultra low distortion.
I'm running an ELF amp, factory head unit. AVC off, Bass set at +2 over center, and Treble at +4.
Polks-
1- I could not get any base out of a either a coax or seperate while riding over 25mph.
2- Seperates mounting challanges for surface mount tweeter did not exceed the performance.
3- Rockford 6.5 COAX, much more bass, the magnet is larger, and the contents of the capacitors and other wiring are internally housed, opposed to the Polks. I hear bass till freeway speeds, then of course it's physics...
zuppy51 is offline
post #3 of 6 (permalink) Old 09-19-2013, 12:24 PM Thread Starter
CNMTurner's Avatar
Polks-
Thanks,,, The RF T165 were my 2nd choice.. Seems they may have moved back on TOP..
post #4 of 6 (permalink) Old 09-19-2013, 12:41 PM
The MM series is much better than the DB series. I ran the MM651s in my streetglide for several years powered by an arc ks125.2 amp. They sound great are weather resistant and are durable. Lots of people run them in their boats. This winter I'l go with them in the fairings and the lowers with two RF amps. I'll do the tourpack later.
2013 Ultra
Pics here:
rg_dave is offline
post #5 of 6 (permalink) Old 09-19-2013, 01:23 PM Thread Starter
CNMTurner's Avatar
Thanks Dave.. I looked at the MM's but they are 2.7 Ohms.. I want to go with 4 Ohms so I can run them in parallel with my Titans.. But.. I've seen good reviews about them..
post #6 of 6 (permalink) Old 10-06-2013, 05:07 PM
torqu's Avatar
Did you get them speakers installed yet? Interested in your results.
torqu is offline
risers, has anyone tried them? dthielenhaus Controls & Handlebars 10 07-19-2015 10:56 AM
Has anyone tried shimming the fairing bracket to reduce vibrations? Driftah Do-IT-Yourself 5 05-12-2014 09:49 PM
Has anyone tried the "Flanders Heritage Style" handlebars? zman Equipment-RG 12 03-12-2012 10:17 AM
Anyone tried a Fatboy fender with a 21" wheel? ScooterDog *General Road Glide Discussions/Pictures 1 01-27-2011 10:05 AM
Anyone tried these deflectors yet? ncbeast Windshields 2 06-26-2010 06:44 AM
