running amp power wires - Road Glide Forums
post #1 of 6 (permalink) Old 06-03-2011, 05:48 AM Thread Starter
Will start upgrade on audio and want to know if there is a way to run the amp power wire and ground without removing the tank?
spender9 is offline
post #2 of 6 (permalink) Old 06-03-2011, 09:17 AM
xusnatc's Avatar
Get your self a clothes hanger and duck tape the power wire to the hanger. Now carefully feed it under the tank and be careful that you dont force it too much. I did it this way, but loosened up the tank bolts so it would move a little bit. Real easy to feed.
xusnatc is offline
post #3 of 6 (permalink) Old 06-03-2011, 09:22 AM
MassHD's Avatar
First to fish a wire under the tank you still have to remove the center console. So removing the tank is 3 bolts and a quick disconnect for the fuel. One a scale from 1 to 10 it's a 1. If you are looking to do it quick I would run it over the tank and under the console.
2010 Road Glide Denim Black
ABS Cruise Factory Security, Black D&D 2 into 1
Firecap's Arc Amp 125.2, 4- Hertz 6 1/2" Speakers
PYO Bars, CVO Rear Fender, KW Wrapper Front Fender
"Burn Rubber Not Your Soul"
MassHD is offline
post #4 of 6 (permalink) Old 06-03-2011, 11:53 AM Thread Starter
Was'nt sure about the tank removal. Sounds easy enough. Not looking for a quick way, just want the wires in the harness.
spender9 is offline
post #5 of 6 (permalink) Old 06-03-2011, 03:28 PM
BostonPhil's Avatar
Don't ise a hanger, you'll scratch the paint.
find a 4' long wire tie, and cut the locking end off.
This is what we use in the car audio industry as a wire snake, and it will not scratch the paint.
L. Phil Chartier
2011 RGC Sedona Orange
- CycleVisions +2 Bars w/PM Elite Grips/Ness mirrors
- Sinister Stretched bags w/ Cycle Sounds 6"x9" Lids
- BADDAD fender w/ custom lighting
- HID headlights & directional delete
- Sony DSX-MS60 w/ 2 WetSounds SYNMICRO amps, Hertz HSK-165XL & Hertz HXC-690
- Corbin Solo seat
- SMW 21" contrast cut Legend front wheel
BostonPhil is offline
post #6 of 6 (permalink) Old 06-03-2011, 07:37 PM
I agree with MassHD - removing the tank is a 1 on a scale of 1-to-10 and is the best way to run the power wire. This way it can be tucked inside the plastic wiring channel that runs over the backbone & protects the wires. It's very easy.
2013 CVO Road Glide Custom, Atomic Orange & Galaxy Gray, RC-Xhaust Slip-ons, Mustang seat, & Garmin Zumo
SixSixRider is offline
SE Phat Plug Wires or OEM Plug Wires wevsspot *General Road Glide Discussions/Pictures 31 07-07-2017 10:17 AM
how to remove power terminal on gps wires jethro_3 GPS 3 01-02-2017 07:35 AM
Not running wires internally? firehouse18 Controls & Handlebars 26 01-01-2013 06:34 PM
Running internal wires hamer007 Controls & Handlebars 5 12-09-2012 03:15 PM
Running wires internally on Heritage bars x52gnr Controls & Handlebars 3 04-22-2011 11:53 AM
