installed amp, now feedback thru speakers - Road Glide Forums
post #1 of 10 (permalink) Old 09-21-2013, 11:19 AM Thread Starter
I just installed a small amp to give the sound a boost over the exhaust. Not a lot of money so I went for a cheap unique cycle 300w unit. I ran a direct line to the positive with 16 ga. solid copper. The ground is their wire to the frame. Started it up and constant interference. So I thought maybe the power was too small a gauge so I ran a pc of 12ga solid copper, but still the same noise. Did the same for the ground. No luck. Anything else I should be looking at?
Quickster is offline
post #2 of 10 (permalink) Old 09-21-2013, 11:57 AM
Q-Hog's Avatar
Verify that you have a good/solid ground connection..
Q-Hog is offline
post #3 of 10 (permalink) Old 09-21-2013, 12:33 PM
What does the interference sound like, is it only present with the bike on and engine running, does it change with the engine rpm?
Sent from my SPH-L710
post #4 of 10 (permalink) Old 09-21-2013, 10:06 PM Thread Starter
it's spark plug interference. It goes up and down with the throttle. You can hear the motor in a low buzzing. I have it grounded to one of the inner fairing mounting bolts, just below the hooks to hang the fairing.
post #5 of 10 (permalink) Old 09-21-2013, 10:52 PM
Rig Magician's Avatar
Run your ground back to the negative of the battery. Also be sure to use stranded copper wire, solid wire will break with the vibrations.
Mark
You have to be tough if you going to be dumb!!!
Rig Magician is offline
post #6 of 10 (permalink) Old 09-21-2013, 11:12 PM Thread Starter
I was thinking about running a ground back, but didn't know if totally isolating it was a good idea.
post #7 of 10 (permalink) Old 09-21-2013, 11:54 PM
RhinoHD's Avatar
Get a ground loop isolator it will fix ya right up. You can find them all over the net or stop in at a best buy that has a car audio department. There is also an old school trick see the video below.
http://youtu.be/dY3gD-j4SVs
Life is good but it's not easy!
RhinoHD is offline
post #8 of 10 (permalink) Old 09-22-2013, 09:07 AM Thread Starter
will give it a shot. I was so aggravated I said screw it and disconnected the ground and power, put the fairing back on so I could ride.
post #9 of 10 (permalink) Old 09-27-2013, 07:45 AM
Your isues is a ground loop. Following Rig Magician's advise will solve the issues. Also, I'd replace the 16 gauge solid "hot" wire with a 10 gau stranded. If the amp is truly pulling 300w you may have issues with the wire overheating and a potential fire hazard.
Good luck and good riding.
Bobby
besjr69 is offline
post #10 of 10 (permalink) Old 09-27-2013, 08:16 AM
Q-Hog's Avatar
Does it make a difference which one of the RCA cables is used?
Q-Hog is offline
Cosmic Blue Pearl feedback & INFO wanted Easyryder01 *General Road Glide Discussions/Pictures 21 08-29-2016 06:29 PM
Daymaker/amp feedback issue madmat Audio 5 05-22-2016 07:40 AM
Brand new J & M ROKKER XT speakers in the box Djtman Parts for Sale 9 02-23-2016 02:27 PM
feedback coming through the speakers scubaz71 Audio 1 07-10-2015 10:16 PM
Engine Noise coming thru my speakers-HELP otis2013 Audio 24 07-16-2014 02:52 PM
