Question for those that know... - Road Glide Forums
post #1 of 3 (permalink) Old 06-05-2011, 07:30 AM Thread Starter
Moderator
BLKNCr6's Avatar
...If I remove my RGU Tour-Pak and therefore remove the rear speakers...with no rear speaker load on the head unit... Do I risk taking out the output transistors for the rear speakers?
What if I add an amplifier? (same question)
It seems to me that running a head unit without speaker load has in my distant past caused the output transistors to blow.
Any thoughts?
...and I used to think my Sportster was heavy...
A Harley will get you through times of no sex, better than sex will get through times of no Harley.
2011 FLTRU
SE Heavy Breather
V&H Monster Ovals
SE Pro Super Tuner to make the above play nice together.
BLKNCr6 is offline
post #2 of 3 (permalink) Old 06-05-2011, 01:15 PM
MyloFiore's Avatar
I will piggy back on this question for those of us with customs, that want to eventually wire up an ultra tour pack (with speakers). I assume an additional amp is needed. Does it go in the fairing, or on the bottom of the pack? Is this even possible to do yourself? What impedance of speakers are needed in back? Do the fronts have to change? How can you wire up the nacelle switch for rear speaker power, and will the stock deck give you a fader control?
Mylo
2011 FLTRX Road Glide Custom
2002 FXSTDI Softail Deuce (sold)
MyloFiore is offline
post #3 of 3 (permalink) Old 06-05-2011, 01:34 PM
SharkNose's Avatar
Don't have an RGU, but on my friend's EGU you can shut off rear speakers via a switch on lower console. Seems that would handle it...maybe?
SharkNose is offline
Question about Softails for those who know... twowheeladdict *General Road Glide Discussions/Pictures 20 05-14-2016 08:57 AM
i know i know i know but....... maddmoe *General Road Glide Discussions/Pictures 2 09-02-2014 07:51 AM
Those who know me will understand Triplej General Off-Topic Discussions 10 01-11-2014 10:02 PM
Question for those in the know? y2kflhr Fuel Moto 10 06-17-2013 06:06 AM
I know....I know.... Fatboy *General Road Glide Discussions/Pictures 12 07-13-2010 02:14 PM
