Arc 125.2 - Road Glide Forums
post #1 of 6 (permalink) Old 09-22-2013, 12:31 PM Thread Starter
Wickedgmc's Avatar
Arc 125.2
I am wondering who else is using this amp?
How did you mount it? I am not very happy with the way it is mounted in my fairing and am looking for ideas. I could buy a PBR300x2 and get a bracket from H-donut for it, but I like the amp.
Thanks in advance for the help
Wickedgmc is offline
post #2 of 6 (permalink) Old 09-22-2013, 03:31 PM
Rig Magician's Avatar
I mounted mine between the inner wall and the glove box on the left side from the front, under the brake lever. A trick I learned is put your sticky back velcro in place then put a thin piece of plastic( I used and old dealer plate from my wife explorer) behind the amp between the 2 sides of velcro. This will let you slide it in easily and postioing it in palce. I also raised the front of the Amp some as it was hitting the fairing. That is how I figured out about the thin plastic. I had to remove the amp and get it further up in the hole there.
I hope that helps,
Mark
You have to be tough if you going to be dumb!!!
Rig Magician is offline
post #3 of 6 (permalink) Old 09-22-2013, 04:10 PM
FLTR2008Trike's Avatar
Here is where I mounted mine
Overcoming Adversity is the path to better ideas!!
S&S 124" Head porting and custom designed cams by John @
10.5 static / 9.41 corrected. Modified V&H Powerdual headpipe with CVO 4" cans and Fullsac 2.25 baffles
FLTR2008Trike is offline
post #4 of 6 (permalink) Old 09-22-2013, 09:45 PM
NorCal's Avatar
mine was also mounted with velcro, it's rock solid.
NorCal is offline
post #5 of 6 (permalink) Old 09-22-2013, 10:33 PM
caboverbob's Avatar
I got 2 of 'me mounted exactly like above, no issue even sitting in Ca sun.
CABOVERBOB PILEDRIVERS LOCAL 34 OAKLAND, CA RIDE IT LIKE YA STOLE IT !
'01 FLTRI, T-header, Big Sucker, Terry Comp, S&S 510G, Road 6 Customs, SMW, Arc Audio, JL, Sidecar Cycles, Progressive, Race Tech, Metzeler, JHC
Build thread
caboverbob is offline
post #6 of 6 (permalink) Old 09-23-2013, 02:07 AM
h-donut's Avatar
or buy a piece of plexiglass -
another member on the board kinda fashioned one up
using the part I make and some additional material
I can send you the link - we talked at length about making a side mount for the bigger amps - I would have to pull my side speakers
once speakers are mounted I don't like removing them, so I dropped the ball, maybe it's fear of destroying the GTX somehow
didn't mean to sound rude about suggesting you replace you ARC with a PBR, but it is a good amp, and inexpensive and loud, and the fitment and application to the bike is more logical
2010 FLTRX- r o a d g l i d e
h-donut is offline
ARC Mini 125.2 Amp and ARC Moto 602--$295 creed Parts for Sale 3 11-22-2017 05:52 PM
Arc 125.2 amp 09Sharknose Audio 7 05-05-2012 06:26 PM
Arc 125.2BX vs RF PBR300 InMotionJosh Audio 3 11-09-2011 03:24 PM
WTB ARC AUDIO KS 125.4 MINI 500W amp - used or inexpensive Timinfla2 Classifieds Archive (3 months old+) 0 04-24-2011 10:54 AM
