Amp Question - Road Glide Forums
post #1 of 8 (permalink) Old 09-26-2013, 03:05 PM Thread Starter
CSM11's Avatar
Amp Question
I want to add an amp to my radio. My question is to be able to add a couple speakers later can I buy a 4 channel amp, or can I run 4 speakers eventually off of a 2 channel. I want to purchase the right amp to be able to upgrade later. Hope this makes sense. Thanks
CSM11 is offline
post #2 of 8 (permalink) Old 09-26-2013, 03:27 PM
mmfinn's Avatar
You can get a 2channel and connect 4speakers to it. I have the HW RS400 amp and 4 Hertz speakers. The ohms from each will determine how you wire them.
mmfinn is offline
post #3 of 8 (permalink) Old 09-26-2013, 03:46 PM
ITOLDU's Avatar
What he said yes a good 2 channel amp will run 4 speakers
ITOLDU is offline
post #4 of 8 (permalink) Old 09-26-2013, 07:43 PM
h-donut's Avatar
+1 and it's more efficient use of space
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #5 of 8 (permalink) Old 09-27-2013, 07:35 AM
CSM11,
Be careful which 2ch amplifier you purshase. Most modern amplifiers will be able to handle a 2ohm load (2 x 4ohm speakers per channel). Some, however will not. Make sure you look for this warning when purshasing the amplifier or ask the retailer.
Bobby
besjr69 is offline
post #6 of 8 (permalink) Old 09-29-2013, 10:07 PM
ERod62's Avatar
Originally Posted by besjr69 View Post
CSM11,
Bobby
+ if amp have gain or frequency response adjustments will cause speaker or amplifier damage if not setup properly.
Best to get the 4 channel even if using only 2 channels easy to add speakers latter. Good amp is costly spend wisely.
FYI if using stock radio 2 ohm speakers J&M 500 wt 4 channel is set to plug and play from the factory for the HD radios.
ERod62 is offline
post #7 of 8 (permalink) Old 09-30-2013, 06:38 AM
ScreamingSkulls's Avatar
Or to add more confusion, buy 2 4 channel amps and really good speakers then bridge both amps to their own set of speakers and pound the crap out of them.
ScreamingSkulls is offline
post #8 of 8 (permalink) Old 09-30-2013, 10:09 AM
h-donut's Avatar
my rockford PBR300x2 is 190+w x 2 @ 2ohm
but it's random, my second one is rate 10w per channel lower - and still over runs a set of HAT 250w max speakers in the lids
I use a 86Hz crossover point, for the front, just a shade above the first line on the dial, and a gain of about 5.5
run 4 speakers from those 2 channels, and initially blew all 4 speakers within a year, & added lids so I wouldn't drive the front 4 speakers so hard, it worked, but one amp will rock the house, and drive 4 speakers easily
rockford 2 channel is the only "non-motorcycle specific" brand I would recommend
soundstream, will save you $20, but then your stuck with issues from fitment to noise abatement to tuning and remote capabilities
beyond that hawg wired
aside from the variable crossovers, the rockford PBR300x2 has a PEQ which is much quicker and instant for making sound adjustments while riding v. menus
since most of your dynamic sound comes from bass strikes, always find a speaker that are at least 250w max, and timber and output matched if plan on pairing them in series or parallel.
I prefer parallel
h-donut is offline
DETAILS - PA & MD (& VA & ??) Meet & Greet 2017 08Zinc Organize Rides Here 28 05-10-2017 01:50 PM
Brand new J & M ROKKER XT speakers in the box Djtman Parts for Sale 9 02-23-2016 02:27 PM
Question about 4 ch 500W J&M amp w/ 2013 RG Harman Kardon McGruder Audio 6 05-26-2015 05:08 AM
J&M 250 Amp question for JM John or anyone that has an answer AndyM Audio 7 01-27-2014 08:23 AM
Amp fit question -Newbie Question Slider57 Audio 13 05-17-2013 11:47 AM
