6.5's that can handle pbr300x4 - Road Glide Forums
post #1 of 13 (permalink) Old 09-30-2013, 09:18 AM Thread Starter
I currently have a pair of Polk Dxi 650's and a pair of infinity kappa's in my glide both are distorting at anything above half vol after a long 13 hr run with the music up loud (interstate) riding id like to find some that can take the abuse of the pbr300x4 amp ? Suggestions?
One set is behind the fairing and one set is in the CVO street glide lower speaker boxes
Thanks in advance.
2011 RGC, detach king tourpack 103 powerpack, direct link super tuner, big sucker air intake, gutted cat, V&H Monster Rounds, santee mini apes, 12"WV & 14"WV, sanchos wings, J&M 7.25 and much more to come!
im 6Ft tall with a 32 inseam
2009 FLHX red hot sunglo, blacked out,arlen ness big sucker, race tuner, bub7 exhaust, [email protected] 87hp 109tq wild one 12" bagger bars, heat deamons.SOLD
2005 FLSTF F.F. edition, chrome everyting, vance & hines short shots. remap, stage 1 air intake.SOLD
ffhd05 is offline
post #2 of 13 (permalink) Old 09-30-2013, 10:14 AM
h-donut's Avatar
ideas
1. another set of kappa's
2. migrate to the PBR300x2 with better software and features
3. hawg wired ZX
4. swap listening positions of the speakers
5. bass blockers on the polks
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #3 of 13 (permalink) Old 09-30-2013, 02:23 PM
zuppy51's Avatar
I'm running the T165 Fosgates with the PBR300x(4). They are perfectly matched at the RMS. They are broken in, with extremenly low distortion.
I think only at full volume with the very heavy bass do they distort.
I've run them at peak for hours on long rides, never a problem.
The reason for the 4 channel for me, is I have a tourpak. I routed a pair of leads with quick disconnect plugs to the rear of the bike. When I install the tour pak for long rides, I just plug them in. The amp is pre-set with the gain and frequency. It's amazing how well they sound.
zuppy51 is offline
post #4 of 13 (permalink) Old 09-30-2013, 03:26 PM
rageglide's Avatar
I killed a set of Hawg Wired 6.5's in short order with their 120watt amp, so I'm guessing they wouldn't hold up under those conditions with the pbr300 either...
2012 fltrx
rageglide is offline
post #5 of 13 (permalink) Old 09-30-2013, 05:02 PM
Shark of the Month August 13
SIC_26's Avatar
I don't want to say I was "disappointed" with my ZXs but.......I did expect more from them. Everyone I ride with loved them though they were powered by a PBR 300x2
SIC_26 is offline
post #6 of 13 (permalink) Old 09-30-2013, 05:10 PM
CNMTurner's Avatar
Hey HHFD05
What head unit are you running?
Is it possible that you have the gain set too high on the amp?
On head unit, do you have bass bumped up.. I did and it was causing similar problems.. I now run it flat (bass and treble set around 0), I have the Stock HK head unit with PB3002
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
post #7 of 13 (permalink) Old 09-30-2013, 05:19 PM
SIC_26's Avatar
I was running the HK head unit with bass and treble turned down to 0, I just expected more outta it I guess.......had polks in the inner fairing and ZXs in stock location, each set of speakers with there own PBR 300x2 it was loud and clear and everyone within 3-4 bike could hear me, I just though/expected more Ol lady couldn't hear much when we were going down the road
I turned the volume up to the "E" and adjusted my gains from there.......til speakers clipped then backed it of a bit. Each amp separately
Said screw it this time LOL and not messing around with any of that stuff ITOLDU loaned me the money for my new setup he just doesn't know it yet
SIC_26 is offline
post #8 of 13 (permalink) Old 09-30-2013, 05:23 PM
stripclub's Avatar
If you are running a factory head unit, set the gains on the amp with the volume on the head unit about 3/4 the way up for the max volume, and never take the volume past that. The factory head unit starts sending out a distorted signal any higher than that, so you are already putting a distorted signal into the amp, in return you are getting a amplified distorted output to the speakers. I am running six RF 6 1/2 in the fairing and lowers, two RF 5 1/4 in the tour-pak pods, two RF 1" tweeters with two RF crossovers in the fairing, and two RF300PBRX4 with the factory head unit and the gains set that way and sounds great without distorting.
stripclub is offline
post #9 of 13 (permalink) Old 09-30-2013, 05:31 PM
SIC_26's Avatar
Yessir, that it's what I did. Like I said, it didn't sound bad. Was clear and loud, just expected more
High end speakers and better amp should do it this go around, spending the $$ and doing it once
To quote "hurt 'me with them Hertz"
SIC_26 is offline
post #10 of 13 (permalink) Old 09-30-2013, 05:45 PM
rageglide's Avatar
I'm fairly confident what killed my ZX's was me not disabling the HK's auto volume level and running volume above half way. I'm sure it had nothing to do with the mild mannered metal mix....
2012 fltrx
I Can't Wait I Can't Wait I Can't Wait......The Outdoors SteadyEddie General Off-Topic Discussions 15 05-19-2017 02:57 PM
Rockford Fosgate PBR300X4 is here pasa Audio 82 11-07-2013 09:11 AM
Install RF pbr300x4 amp? GLYDDN11 Aftermarket Accessories 2 01-29-2012 06:45 AM
Girl can handle Sharks DreamRider Videos 7 10-23-2011 07:00 PM
Fosgate PBR300X4 SGT_Rob Audio 1 09-10-2011 10:43 AM
