Mentra Antenna Install Advice - Road Glide Forums
post #1 of 5 (permalink) Old 06-24-2011, 08:14 AM Thread Starter
Metra Antenna Install Advice
I am going to be replacing the factory antenna with the Metra under the fairing on my 2010 RG.
Where is the best place to mount the antenna?
As far as power I was told to tap off of the lighter, does anyone have a suggestion for a grounding point?
Thank you
bbass is offline
post #2 of 5 (permalink) Old 06-25-2011, 02:03 PM
Carisma Audio's Avatar
In my installs I use the cig lighter power and ground, Mounting below the center of the inner fairing above the radio.
Carisma Audio is offline
post #3 of 5 (permalink) Old 08-08-2011, 08:00 AM
Can one of you provide some more detail on the Mentra antenna (product/model number)? A photo of the install would be cool too. Thanks!
bonedog42 is offline
post #4 of 5 (permalink) Old 08-08-2011, 09:00 AM Thread Starter
I went with Metra Deluxe Universal Amplified Antenna (P/N CK-UA200), it looks just like the HD antenna less the HD logo. I was able to get power from the red capped connector (if I remember correctly I believe the wire was orange with a white stripe) which is located approximately 4" down below the left side connector of the radio when facing the front of the bike. See the link below for pics.
https://www.roadglide.org/search.php?searchid=574574
bbass is offline
post #5 of 5 (permalink) Old 08-08-2011, 09:57 AM
wachuko's Avatar
Cool
This is what I did... click on the link:
Hidden Amplified Antenna Install - 2011 RGC
Ride Safe! Wachuko - 2016 HD Softail Slim S / 2016 Triumph Thruxton R
2014 RK CVO Tribal Orange-Galatic Black (Gone) / 2013 HD Forty-Eight in Ember Red Sunglo (Gone)
wachuko is offline
HD Hidden Antenna Install Rushmore/Question FLTRXS18 Do-IT-Yourself 2 10-24-2017 06:34 PM
Remove Rear Antenna- Add Hidden Antenna- Hurt Reception? scottrgs Audio 4 09-06-2017 10:34 AM
Metra Amplified Antenna Install Grind Audio 7 05-24-2013 08:12 AM
Hidden Antenna advice? harley hauler Audio 13 01-31-2012 12:03 PM
Hidden Amplified Antenna Install - 2011 RGC wachuko Do-IT-Yourself 10 10-28-2011 12:34 PM
