Inner Fairing Speakers & Amp - Road Glide Forums
post #1 of 4 (permalink) Old 10-08-2013, 07:03 PM Thread Starter
I have a quick question about adding speakers/amp in the inner fairing. I currently have a RF PBR 300x2 with J&M speakers in the standard location. I want to get a little more /better sound and plan to add the inner fairing speakers. Should I add another amp to power these or will I be able to run off the existing amp?
Thanks
gfyoung3 is offline
post #2 of 4 (permalink) Old 10-08-2013, 07:47 PM
Wildmank99's Avatar
I have all four of my Rockford running off my pbr300
2007 road glide black pearl, 103 kit with aftermarket heads and cams, air ride, 2 to 1 bub pipe, and alittle bit of sounds
Wildmank99 is offline
post #3 of 4 (permalink) Old 10-08-2013, 08:38 PM
kouack's Avatar
It Will depend on your speaker impedance if your speakers are 4 ohms and get a second set of 4 ohms speakers you can run them in parrallel off your amp. If they are 2 ohms then you should get an other set of 2 ohms and run them in serie instead. It is not a good idea to run your amp at an impedance lower than 2 ohms overheat\ failure will result.
kouack is offline
post #4 of 4 (permalink) Old 12-18-2013, 04:27 PM Thread Starter
Thanks for the responses - sorry It's been awhile since I've had a chance to get back on this. Since my J&M's are 2 ohm (I think) and I don't want to replace them, I guess I need to get 2 ohm speakers for the inner fairing. Can anyone recommend a set of 2 ohm 6 1/2" speakers that work without having to hack the gloveboxes?
Thanks
gfyoung3 is offline
Can I fit speakers in inner fairing with 4 ch amp? hotdog1922 Audio 12 03-20-2015 12:06 PM
Lower Fairing speakers or Inner Fairings speakers. Looking to "thicken" my sound a bi Tvbird Audio 14 07-24-2014 10:55 PM
inner fairing depth for speakers & Critical Mass speakers vinman4444 Audio 9 01-06-2014 06:58 PM
Inner fairing speakers lowglidin *General Road Glide Discussions/Pictures 0 01-10-2011 07:29 PM
6.5" speakers in inner fairing sportyguy69 Aftermarket Accessories 10 12-15-2010 12:05 PM
