PAC SWI-RC wont program - Road Glide Forums
post #1 of 30 (permalink) Old 10-11-2013, 11:59 AM Thread Starter
Deadstroke's Avatar
Anyone have this unit? I went to program it and it says to hold the button till the light comes on and it never comes on. Once I release it though it comes on and stays on..
Deadstroke is offline
post #2 of 30 (permalink) Old 10-11-2013, 02:32 PM
baghrd's Avatar
I'm sure you have the instructions but you might want to do a reset on it incase something went wrong before. You should hold the button with the bike in the off position, then turn to the on position and the LED will light up, then after releasing the LED will go off, then press the program button the number of times for the version of you PAC, when done the LED will flash the same number of times that you punched for your version, and if correct turn the ignition off. Then turn the bike back on and push the programming button and release it. The LED will stay lit for 7 seconds, then press for 5 seconds the button that is to be programmed based on their chart (the LED will go off during programming of that button and come back on when needed to move to the next button), repeat previous steps for the following control programs.
That is from their website but if all else fails throw it away and get the Hawgwired or Biketronics. They are simple plug and play.
2013 Road Glide Candy Orange
baghrd is offline
post #3 of 30 (permalink) Old 10-11-2013, 02:34 PM
baghrd's Avatar
Use this link straight to their website also has other important information of wires that need to possibly be cut and directions.
http://www.pac-audio.com/swi/SWIAppG...ny&swiOptions=
http://www.pac-audio.com/SWI/pdf/swi...lletin_007.pdf
baghrd is offline
post #4 of 30 (permalink) Old 10-11-2013, 02:36 PM Thread Starter
Deadstroke's Avatar
Thats my issue the LED never comes on to reset it.. I am looking at the biketronics I just didnt want to take off the fairing again!
But then I would have to resoder all the wires back to the stock connection.. Hoping to just get this working but isnt looking good..
post #5 of 30 (permalink) Old 10-11-2013, 07:02 PM
baghrd's Avatar
I would try to have PAC warranty and send you another one before since you have already cut the connectors. If not I would go with the hawg wired just because of personal experience as I have it. My buddy has the biketronics on his street glide and its ok. You can get the hawg wired from Frank at Dragos on a little bit of a discount.
baghrd is offline
post #6 of 30 (permalink) Old 10-11-2013, 07:20 PM
ITOLDU's Avatar
Good luck DS, I have the Biketronics and have gone thru a few with there lifetime warranty. I agree with earlier post if you can't get it to work try and get it replaced under warranty. Good luck.
ITOLDU is offline
post #7 of 30 (permalink) Old 10-12-2013, 09:06 PM Thread Starter
Deadstroke's Avatar
thanks, finally got it working, they cut the orange wire and now it works.. It seeks to to work ok. There is a few second delay but at least it works.. :P
post #8 of 30 (permalink) Old 10-14-2013, 07:03 AM Thread Starter
Deadstroke's Avatar
Oddly enough it stops and starts working.. not consistent.. My issue is I took it to the dealer to install because I didnt have time. I am sure they made a mess of the wiring.. We will see.
post #9 of 30 (permalink) Old 10-15-2013, 08:04 AM
baghrd's Avatar
Depending on what source you are using it can do that. My hawg wired only does it on USB. Everyone I talked to say its because a lot of radios don't have iphone 5 support that is great yet even if you update. On bluetooth I've never had a problem.
baghrd is offline
post #10 of 30 (permalink) Old 10-18-2013, 08:04 AM Thread Starter
Deadstroke's Avatar
Well I narrowed it down it looks like it only refuses to work while the bike is running.. while key is on there are no issues.. Stealer screwed up the resistors or the wiring I am willing to bet..
PAC-SWI-RC Issues Razor37174 Audio 8 02-23-2017 12:35 PM
Alpine 147BT/Scosche install kit/Pac Controler SWI-RC Review RhinoHD Audio 21 03-24-2015 06:01 PM
Biketronics vs Hawg Wired vs SWI-RC madskilz102 Audio 4 01-25-2015 02:58 PM
PAC SWI-RC handle bar switch interface Big_gary Audio 0 09-17-2014 02:57 PM
Scosche Kit and PAC SWI from 702 Motoring StephenRG Audio 2 06-28-2014 12:15 PM
