Boom iPod interface - Road Glide Forums
post #1 of 18 (permalink) Old 10-14-2013, 03:36 PM Thread Starter
eldridgetom's Avatar
Boom iPod interface
Anyone added this? How hard was install? Where does your iPod/iPhone ride and connect?
eldridgetom is offline
post #2 of 18 (permalink) Old 10-14-2013, 06:54 PM
perrykw's Avatar
I went with the HDPD Plus. It gives me full control through the handlebar controls and is a good bit cheaper than the HD version. Easy installation . . . plug in the main harness, hot and ground, mount to top of radio, and route the dock connector. I set mine up to keep my ipod in the right fairing compartment but they sell an extension cord that you can use to put it in the saddlebag
perrykw is offline
post #3 of 18 (permalink) Old 10-14-2013, 07:05 PM Thread Starter
Haven't heard of that one. $150 less than boom audio. Are you pleased with it?
post #4 of 18 (permalink) Old 10-14-2013, 07:10 PM
perrykw's Avatar
I'm very pleased with it. I have never used the HD version, so not sure what the differences are. I know they connect to the radio a little differently, but the dock connector is the same, it charges my Nano, and I can change tracks, etc with the handlebar controls. I used the Ipod through the aux connector a few times before I added the interface. It may be my imagination, but seems like the audio quality is better with the interface. It took a little time to fit the additional wiring in the fairing, but that was probably compounded by the fact that I added the Navigation Interface at the same time.
perrykw is offline
post #5 of 18 (permalink) Old 10-14-2013, 07:33 PM
zemo1017's Avatar
I don't care for the location of the HD interface connector. Moved it out of the saddlebag into the TP. The HD has some flakiness to it though. Will stop playing for no reason and come right back on most of the time. Once in a while it quits playing altogether. Selecting playlist will start it over.
zemo1017 is offline
post #6 of 18 (permalink) Old 10-14-2013, 08:22 PM
moose1's Avatar
I also run the HDPD plus and really like it I can't remember the last time I used the radio. The one thing that would be nice is if the wire harness was longer that's a lot of wires you have to bend out of the way to get the fairing on
Sent from Motorcycle.com App
2012 FLTRU vivid black
moose1 is offline
post #7 of 18 (permalink) Old 10-14-2013, 08:27 PM Thread Starter
So does y'all's iphone go in your glove box? Is it wire free? I don't want a lot of wires everywhere. I'd like to be able to charge my phone while listening to pandora.
post #8 of 18 (permalink) Old 10-14-2013, 08:40 PM
perrykw's Avatar
I don't have an Iphone, but the only wire you can see on my interface is the dock connector wire. Nothing plugs into the front of the radio. It all goes in the back inside the fairing
perrykw is offline
post #9 of 18 (permalink) Old 10-14-2013, 08:45 PM
moose1's Avatar
There's just a cable that plugs into your iPod or phone I drilled a hole into my left glove box and ran it into there. The wires are all inside the fairing and if you don't have a ultra there's not near as many wires in the harness
moose1 is offline
post #10 of 18 (permalink) Old 10-14-2013, 08:49 PM
shermanator's Avatar
I have the HDPD plus. I have the connector go in to the right compartment on the fairing. Just plug in my Iphone.
Does anybody else have this probem. When you shut the bike off & then turn it back on your music starts at the beginning again instead of just resuming where it left off. Is this normal.
shermanator is offline
Problem with ipod Nano and/or HD iPod Interface wingman05 Audio 29 09-17-2014 07:48 AM
Replacement iPod cable from Boom Audio iPod interface kit McGruder Audio 7 04-21-2014 05:08 AM
Ipod HD. interface needed if one uses J&M NEW Ipod interface??? hogger Audio 2 10-22-2013 02:28 PM
Boom!™ Audio iPod® Interface? Not_A_CVO Audio 30 04-22-2012 09:21 AM
boom audio ipod interface question ??? THEMASTERDESTROYER Audio 7 10-21-2011 07:38 PM
