Anyone running an ARC Audio amp @ 2 Ohm? - Road Glide Forums
post #1 of 4 (permalink) Old 10-20-2013, 08:23 PM Thread Starter
Sedona103's Avatar
I am planning to run my Arc 125.2 to power 4 polk mm651um speakers and was wondering if anyone else had much luck doing so? I might have to step up to a 4 channel but was hoping not to.
2011 fltrx w/ 103.
My build thread.
Sedona103 is offline
post #2 of 4 (permalink) Old 10-23-2013, 02:37 AM
h-donut's Avatar
well, the MM series polks are 2.7 ohm, so two pairs would make a nice wide 4ohm load wired in series
the 4ohm load is said to be much quieter on that amp.
other note: UM have fixed bezels and are harder to fit on bike and some huge assed magnets
the black MM651's with the tiny neo magnet's are the ones you want, think
wired in series is the scary one where you cross wire one positive on one speaker to the negative of the other speaker, then run the opposing leads, + and minus from the two separate speakers to the amp.
not scary, just one of those things, I always check the speaker load before just trying it out with a ohm meter
you do get a louder output wiring in parallel, usually, but depends on what you have in parts, in the case of the MM series, they're throw a 1ohm load and more than likely sound really good for about 10 minutes and then the amp would cook.
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #3 of 4 (permalink) Old 10-23-2013, 06:58 PM
ITOLDU's Avatar
I ran my arc like that before I added more speakers and more amps.
ITOLDU is offline
post #4 of 4 (permalink) Old 10-23-2013, 07:21 PM Thread Starter
Sedona103's Avatar
I might just have to pick up a new amp.
2011 fltrx w/ 103.
My build thread.
Paralleling speakers 4 ohm 2 ohm using amp set up to parrallel Heavy Metal Audio 16 01-06-2018 06:09 PM
Arc 602 Speakers & 600.4 Arc Amp- anyone running bridged? scottrgs Audio 5 03-22-2017 07:06 AM
Speaker question 2 OHM or 4 OHM Ginee13 Audio 3 09-22-2015 05:53 AM
switching from 4 ohm to 2 ohm at a later date chevjerico Audio 3 05-15-2014 01:24 PM
4 ohm and 2 ohm speakers yamahoe72 Audio 7 04-13-2013 07:55 PM
