tweeters in gauge holes - Road Glide Forums
post #1 of 26 (permalink) Old 10-22-2013, 09:26 AM Thread Starter
What do you guys who have tweeters in the gauge holes use so that it is sealed in there well? Some sort of rubber trim? Thanks. Links are always appreciated.
HogPro is offline
post #2 of 26 (permalink) Old 10-22-2013, 09:30 AM
I know Hawgwired makes an adapter, might want to ask Mike or Justin if they use anything. Personally I love gauges so I mounted my tweeters in the grills.
Sent from my SPH-L710
post #3 of 26 (permalink) Old 10-22-2013, 09:37 AM Thread Starter
How did you mount them in the grills? They came with the grill mounts?
HogPro is offline
post #4 of 26 (permalink) Old 10-22-2013, 09:56 AM
RichieRich's Avatar
The CVO RG came like that so there has to be a HD part number. PC pain should know.
Sent from Motorcycle.com App
2013 BBP FLTRX
RichieRich is offline
post #5 of 26 (permalink) Old 10-22-2013, 11:01 AM Thread Starter
Does anyone have the hawg wired grills with the tweeter part in them? I think I'll do it this way as I prefer keeping all my gauges as well. I have no problem sacrificing the air temp gauge, but between voltage, oil pressure and gas, I am not sure which i would elimiante. Probably I would elimiante gas but if I can get a grill to put them in which I can I will.
HogPro is offline
post #6 of 26 (permalink) Old 10-22-2013, 11:16 AM
I bought the Hawgwired mesh grills, measured my tweeters, and used a hole saw. I drilled them to the close to the size of the tweeters and then firmly but gently forced the tweeters in, it worked out nicely.
post #7 of 26 (permalink) Old 10-22-2013, 11:20 AM
Here's a picture from my phone.
post #8 of 26 (permalink) Old 10-22-2013, 11:31 AM
RichieRich's Avatar
That looks pretty dang slick
2013 BBP FLTRX
post #9 of 26 (permalink) Old 10-22-2013, 12:16 PM
Q-Hog's Avatar
I used the stock speaker housing & just drilled a matching hole to match the tweeter. I used the HW speaker grill.
Q-Hog is offline
post #10 of 26 (permalink) Old 10-22-2013, 12:40 PM
ldireprophil's Avatar
I'll take some pics of mine later night. Cosmetic rings came with my Hertz tweeters. Little silicon. Clean and tight.
ldireprophil is offline
Polk mm6501 tweets in gauge holes jason605 Audio 7 03-15-2015 11:15 AM
tweeters in the gauge pods Othello7213 Audio 10 10-13-2014 12:27 PM
What size tweeters? GLYDDN11 Aftermarket Accessories 6 10-27-2011 07:12 PM
2012 cvo spaekers and tweeters THEMASTERDESTROYER Audio 10 08-12-2011 10:50 PM
Tweeters? Ny Chief Audio 0 06-15-2011 02:57 PM
