XM antenna - Road Glide Forums
post #1 of 11 (permalink) Old 10-25-2013, 02:30 PM Thread Starter
XM antenna
I have XM radio on my 2013 RG and the antenna is mounted under the fairing. Every time a bird flies over, I lose signal. Has anyone had any luck mounting the antenna elsewhere on the bike?
Thanks,
Kudu40
Kudu40 is offline
post #2 of 11 (permalink) Old 10-25-2013, 04:07 PM
I moved my antenna around a bunch and finally found the best spot being right on top of the radio under the fairing. I had even tried the factory antenna bracket that connects to the side of the radio, but I lost signal whenever riding west. Since moving it to on top of the radio, I have had zero reception issues except the expected ones when riding under really wide overpasses.
MilesOfTexas is offline
post #3 of 11 (permalink) Old 10-27-2013, 03:36 PM
SEUGOT1's Avatar
Miles.....did you mount your antenna 'level' on top of your radio? I have moved mine out from under the fairing to the farthest spot w/o interfering with the fairing going back on. My problem before was I couldn't pick up any stations going south, now its spotty going north. Of course I am just about to the point of dropping xm b/c they are always screwing with stations you like by dropping them....i.e. Sixx Sense ch 242
2018 FLTRXSE, Freedom 13" windshield, SOUNDZ amp, Iron 65 fairing & lower speakers, Iron 57 saddlebag speakers, Fullsac MX pipe, CVO power cores, Corbin dual touring seat, Ohlins 159 shocks, JH Choppers Performance floorboards, Pingel floorboard extenders, King tour pak w/chopped backrest, Metalsport luggage rack, Ciro3d cupholders, Avon grips
SEUGOT1 is offline
post #4 of 11 (permalink) Old 10-27-2013, 03:54 PM
RoadGlideRider's Avatar
I tried several places under the fairing for mine. I even had it in the center of the radio,
but the metal windshield trim would sometimes block the signal. I found that I had my best reception when I put the magnetic antenna up on the lip of the radio under the inner fairing. I balanced it on the metal sticking up on the front of the radio. This held the antenna flat in relation to the ground.
When I get my RG back from the transmission repair, I am replacing the AM/FM antenna and will take a current picture of the SIRIUS antenna.
RoadGlideRider is offline
post #5 of 11 (permalink) Old 10-27-2013, 07:13 PM
Jay2Beers's Avatar
Thanks for the info and pic RGR. Cheers!
'13 Blk RGC crs/abs/sec 103 Stg2 255cam-plus D&D Boss Fatcat SE Super Tuner. Klockwerks 12", Blk 10"Chubby w/Blk Get-A-Grips. Skunked Day Maker. CD GEN2001157Amber/Wht Front & Red Rear Smoke Lens w/Magic Strobe & bits more, Always a WIP
Jay2Beers is offline
post #6 of 11 (permalink) Old 10-28-2013, 06:06 PM Thread Starter
I have no idea what the antenna looks like but is it possible to mount the XM antenna opposite the stock antenna on the rear of the bike? Would it look butt ugly?
Thanks,
Kudu40
Kudu40 is offline
post #7 of 11 (permalink) Old 10-28-2013, 10:27 PM
Groundhawg's Avatar
Kudo40 -
The XM antenna is just a black hockey puck looking deal about 4" in diameter with a magnet inside. You can just barely see it in the pic above...
Good luck!
Groundhawg is offline
post #8 of 11 (permalink) Old 11-23-2013, 10:32 AM
adown's Avatar
I made a bracket that mounts the radio and holds the antenna. I also cut the antenna down to 8". I need to do the same to the audio cord.
adown is offline
post #9 of 11 (permalink) Old 11-23-2013, 12:55 PM
Peewee's Avatar
I did something similar to Adown. I used a peice of two sided tape and stuck it to the top of the dash. Zero issues (other than the stuck under a bridge)
"Know Thyself"
Peewee is offline
post #10 of 11 (permalink) Old 11-24-2013, 03:01 PM
Glide08's Avatar
Have you ridden with that setup .It looks like going North you would lose signal
Glide08 is offline
WTB - GXM40 Antenna - Garmin XM Radio gakarl Wanted! (Buy or Trade) 1 08-26-2013 04:07 PM
Garmin XM Antenna Puck placement rrs49 Equipment-RG 10 06-03-2012 04:34 PM
Best place to put XM Antenna? Adam6946 Audio 9 05-15-2012 10:36 AM
Check Antenna - XM Module Speedie Audio 1 03-31-2012 10:01 AM
XM antenna location ? spender9 Audio 3 06-12-2011 04:26 AM
