Looking to upgrade? - Road Glide Forums
post #1 of 5 (permalink) Old 10-25-2013, 06:21 PM Thread Starter
StGhost's Avatar
Looking to upgrade?
What I have is HD head unit, RF PBR300X2 and JM7252GTM. Thinking about putting some speakers in the inner fairing. They will need to be 2ohm speakers run in series. What would be good? Trying to get a little more bass. Would installing a PEQ help?
StGhost is offline
post #2 of 5 (permalink) Old 10-25-2013, 10:18 PM
h-donut's Avatar
PEQ is designed to tweak adjust for road noise, I think it helps
as far as HighOutput 2ohm speakers, Kappa and MM seem to be some favorites
but, the output of the weakest speaker in the line is doubled
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #3 of 5 (permalink) Old 10-28-2013, 05:35 PM Thread Starter
StGhost's Avatar
so what would you recommend to do? MM?
StGhost is offline
post #4 of 5 (permalink) Old 10-28-2013, 07:33 PM
h-donut's Avatar
seems like the logical choice, the smaller magnets would require less trimming
they are sharp looking parts, the grills might be a little large, you can move out the lower fairing supports or find slimmer grills
the MM spl's are high also, around 93-94db - will make good use of energy
note on the PEQ: from installing one on each amp, the boost 12 or 18db goes hand in hand with how the crossover is setup
either HI only , HI and LOW , or LOW only
the LOW only boost cuts your high end off and I don't feel the amp really has enough power to run an open air LOWs
I installed 2 PEQ dials, left one treble, right one bass
with the HP filter set at 87Hz like I have mine, PEQ actually works as a treble boost for that amp, the sweet spot being about 60%, brings out the cymbals and vocals a little
not so much a boost, but a fine tune adjustment similar to a mid shift
I set the rear channel to full since the 5x7's can handle the lows without clippping, again at about 60% is the sweet spot, usually with the HAT speakers use it around 20-30% as a fall back point when the highs get too intense
as far as just getting LOW, I found that the HP crossover did help, because the speakers could travel more freely not having to try and reproduce the tones designed for 15" stadium speakers
actually sat there and watched the movement of the cones with and without the crossover, with the crossovers on, the cones were moving with the song perfectly, without the crossover, in AP mode the cones would bog and not get nearly as loud
I'd try the MM's - if I didn't already have something that works well, they're on my short list
h-donut is offline
post #5 of 5 (permalink) Old 10-29-2013, 08:30 AM Thread Starter
StGhost's Avatar
Thanks, I will be getting with you for a mount for the amp when I get ready to start working on it. I have the amp on top of the head unit with Velcro for now.
StGhost is offline
Looking for upgrade ideas for 2001 FLTRSEI2 Joesquid Audio 9 01-13-2015 01:06 AM
Looking for a simple headlight upgrade macked Lighting 17 05-23-2013 10:29 AM
Not much of an audio guy...but I'm looking for upgrade 13-FLTRX Audio 10 12-11-2012 06:54 AM
Newbie looking for EFI upgrade info nking262 ECM/Fuel Management systems 5 09-09-2012 07:23 AM
Looking to upgrade stereo glidethru Audio 1 06-22-2012 07:03 AM
