AMP installation - Road Glide Forums
post #1 of 6 (permalink) Old 10-31-2013, 10:51 AM Thread Starter
OKBigD's Avatar
AMP installation
So those of you guys who have installed multiple amps, are you using automotive power components? Meaning AGU fuse holder, power distribution block? I'm concerned about the vibrations that my power harness will get on the bike, and am not sure how well the screw down terminals will hold up.... Thinking soldering may be better..... Any thoughts.....
OKBigD is offline
post #2 of 6 (permalink) Old 10-31-2013, 11:56 AM
Shark of the Month August 13
SIC_26's Avatar
I run automotive grade without issue, to date....
I just strip and twist the end of the cable and solder it so it's one price vs 100s of staines then insert into fitting and tighten, tight is tight then a little more
Ran my black and green bike with 2 amps this way and didn't have any issues
Sent from Motorcycle.com App
SIC_26 is offline
post #3 of 6 (permalink) Old 10-31-2013, 12:16 PM
caboverbob's Avatar
I bought some in-line 8 ga. AGU fuse holders, hooked them up directly to the battery, soldered/shrink wrapped connections to cable running forward to 2 Arc Audio amps in the fairing.
Might be a pic of it on my build thread, haven't been on here much lately, so I'm not sure.
Peace
CABOVERBOB PILEDRIVERS LOCAL 34 OAKLAND, CA RIDE IT LIKE YA STOLE IT !
'01 FLTRI, T-header, Big Sucker, Terry Comp, S&S 510G, Road 6 Customs, SMW, Arc Audio, JL, Sidecar Cycles, Progressive, Race Tech, Metzeler, JHC
Build thread
caboverbob is offline
post #4 of 6 (permalink) Old 11-01-2013, 02:14 PM
h-donut's Avatar
lightening audio has a 0-4-8 block on ebay for about $8 with 2 sets of fuses included
that is what I used, I had to trim the battery box to accept a 4 gauge power to block, about 1 foot
grounded to the frame, but to the battery seems to work also
there are some kits out there from knu concepts on amazon that have all in one of what you'll need.
8ga kit is sufficient even for two amps, 17ft of 8ga, 4ft of ground, 20ft 16ga speaker wire, something like that
screw in terminals are fine for the 8/10ga wiring, I'd solder the speaker wiring
hope that helps
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #5 of 6 (permalink) Old 11-01-2013, 02:59 PM Thread Starter
OKBigD's Avatar
Thanks guys... That's exactly what my plan was to use those components... I just wanted to see what's worked for others.....
OKBigD is offline
post #6 of 6 (permalink) Old 11-01-2013, 03:43 PM
I use a distribution block inside the fairing to supply power to multiple amps.
Sent from my SPH-L710
RF amp installation question rustyj671 Audio 21 11-09-2012 01:23 AM
Installation at BB&BBQ? Yellow09SERG J&M 3 07-07-2012 12:36 PM
Need help troubleshooting J&M Rokker installation Stick_FSMC Audio 18 07-01-2012 11:34 AM
Need help troubleshooting J&M Rokker installation Stick_FSMC J&M 2 06-04-2012 11:12 AM
Ohlins & Bub 7 Stealth Installation/Review jwd98056 Intake and Exhaust 8 01-12-2012 06:33 PM
