Noise or interference - Road Glide Forums
post #1 of 11 (permalink) Old 11-12-2013, 04:38 PM Thread Starter
just finished fitting a new system
RS400 - Reference Series 400W Amplifier
ZX654-100 - ZX Series 6.5 Component Speakers
Kenwood KDC-X 897 head unit.
I am very happy with the whole setup and it is pretty good sound well IMHO anyways
But there is one annoying thing.
What sounds like feed back or interference, a real buzzing .
Any ideas on where to look or what to change?
Appreciate any help
cheers
Max
ozymax is offline
post #2 of 11 (permalink) Old 11-12-2013, 04:58 PM
Do you have LED lights?
post #3 of 11 (permalink) Old 11-12-2013, 07:24 PM Thread Starter
Only what is standard on the bike
ozymax is offline
post #4 of 11 (permalink) Old 11-12-2013, 09:29 PM
sloride's Avatar
Hooking your amp up to the Hi level input side will usually cure this.
sloride is offline
post #5 of 11 (permalink) Old 11-12-2013, 09:31 PM
thedude's Avatar
If that does not work call Hawg Wired. They are very helpful.
thedude is offline
post #6 of 11 (permalink) Old 11-12-2013, 11:16 PM Thread Starter
OK will give it a go maybe a few days, had enough of taking that fairing off
Yes they are, I can't say enough about the customer service, very very impressive
ozymax is offline
post #7 of 11 (permalink) Old 11-15-2013, 07:22 PM Thread Starter
Spoke with Mike at HW and as suggested above switched to Hi level inputs and now it's perfect.
Thanks for the suggestions.
cheers
Max
ozymax is offline
post #8 of 11 (permalink) Old 11-20-2013, 08:51 AM
OKBigD's Avatar
So are you saying you changed from RCA inputs to speaker level inputs?
OKBigD is offline
post #9 of 11 (permalink) Old 11-20-2013, 01:19 PM Thread Starter
yes exactly, Mike explained that some after market head units have a poor earthing arrangement and the best way to resolve it is by using speaker inputs
ozymax is offline
post #10 of 11 (permalink) Old 11-20-2013, 01:25 PM
OKBigD's Avatar
I wonder if grounding the chassis of the head unit to the chassis of the amp would help eliminate this? I've seen RCA connectors with a built in drain wire to help in grounding....
http://www.ebay.com/itm/140899495654
OKBigD is offline
HID Radio Interference twrguy Lighting 0 08-01-2013 06:10 PM
caliper mounted Cree lights radio interference bucketlisthd Lighting 2 03-15-2013 09:34 PM
Radio Turn Signal Interference jimmyray11349 Audio 1 12-10-2012 08:33 AM
Radio Interference? TearlessTom *General Road Glide Discussions/Pictures 3 02-20-2012 06:46 AM
Radio Interference with CD led install DonJulio Lighting 12 02-06-2012 12:56 PM
