fairing speakers - Road Glide Forums
post #1 of 25 (permalink) Old 11-25-2013, 07:59 PM Thread Starter
DB DIESEL's Avatar
fairing speakers
I have been looking at 6.5" Infinity Kappas and really leaning that way, but was wondering...can a 6x9 fit in the fairing? If so, where can I get an adapter? thanks
McKinney, Tx.
2012 Road Glide Ultra
DB DIESEL is offline
post #2 of 25 (permalink) Old 11-25-2013, 08:14 PM
laxinharley's Avatar
As far as I know in the stock position the only adapters they offer are for 6.5 without cutting the fairing a bit. But some audio expert will def confirm or deny that.
laxinharley is offline
post #3 of 25 (permalink) Old 11-25-2013, 10:36 PM
RichieRich's Avatar
Without cutting you can get a 5x7 in there with the CVO adapters. 6x9 would be totally custom
Sent from Motorcycle.com App
2013 BBP FLTRX
RichieRich is offline
post #4 of 25 (permalink) Old 11-25-2013, 11:27 PM
fragmentum's Avatar
Several available on eBay
If your not living on the edge, you're taking up too much room...
fragmentum is offline
post #5 of 25 (permalink) Old 11-26-2013, 11:12 AM
04Glider2's Avatar
Here are some 6X9's in my RG
You can get 6X9's in if you want to take the time to do it.
If you decide to go this way be sure to get some that have the lowest profile grilles possible so you don't have interference with the fork tube bolts.
Here is a link to how I got mine installed:
http://s1092.photobucket.com/user/04...38065454101394
Got the Polk Audio Marine grade speakers at Best Buy and you can get an extended warranty for a reasonable price. Their installer was interested and asked me to come by when I finished. He thought it was a good job, but they are not allowed to do bikes at the store.
04Glider2 is offline
post #6 of 25 (permalink) Old 11-30-2013, 04:53 AM
You can also buy one of the custom inner fairing that have them in the approximate position of the top of the glove boxes. IMO if you put 6x9 in the area where the forks are on the inner fairing you'll be losing a lot of the sound. The 6.5s provide good sound in that position, and you're losing some with them, 69 provide even more. ...... let us know what you decide and how it works out.
Sent from my SPH-L710
post #7 of 25 (permalink) Old 11-30-2013, 05:01 PM Thread Starter
DB DIESEL's Avatar
thanks for the responses. I may try and get ahold of the cvo 5x7 speaker mounts if I can.(don't know if it is a protected part number) If not, I will just stick with the original plan of Infinity Kappa 6.5 in factory locations.(tour pack and fairing) I am putting 2-soundstream Picasso nano pn4.320d in the fairing if possible (if not they can go in the bags), pioneer 6x9 in hogtunes lids and a pair of 8" shallow midbass facing the wheels for a little added low end. I may go as far as building a small fiberglass box for the 8" but not sure yet.
McKinney, Tx.
post #8 of 25 (permalink) Old 12-01-2013, 11:07 AM
JMJOHN
JMJOHN's Avatar
J&M ROKKER XX 7.25" speakers for the RoadGlide offer cone volume and mass comparable to a 6X9" speaker, but all plug-n-play into the RoadGlide fairing, 156w RMS power handling ,,,, see http://www.jmcorp.com/ProductDetail....=HRRK-7252-RXX ,,,,,,
JMJOHN ----
JMJOHN is offline
post #9 of 25 (permalink) Old 12-01-2013, 07:21 PM
Just installed the J&M 7.25 fronts, with the 5.25 rear pods. 500 watt amp, all plug and play. The CVO's do have some different custom connections due to the external amp. Awesome sound, great fit and finish.
SHRK2TH is offline
post #10 of 25 (permalink) Old 12-01-2013, 08:28 PM
ITOLDU's Avatar
subscribed want to see how this turns out. I am going to attack it from a different angle but with same results in mind... a pair of 6x9's, 6.5's and 4x6 speakers in the inner fairing...
ITOLDU is offline
WTB: Hogtunes 24.2 amp and 5x7 speakers - or other speakers w/ rings kyle31490 Wanted! (Buy or Trade) 5 06-16-2015 02:33 PM
Lower Fairing speakers or Inner Fairings speakers. Looking to "thicken" my sound a bi Tvbird Audio 14 07-24-2014 10:55 PM
inner fairing depth for speakers & Critical Mass speakers vinman4444 Audio 9 01-06-2014 06:58 PM
2 speakers or 4 speakers LeotheThird Audio 9 04-13-2013 10:15 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 01:53 AM
