Audio Question - Road Glide Forums
post #1 of 6 (permalink) Old 11-29-2013, 07:03 PM Thread Starter
CSM11's Avatar
Audio Question
Has anyone put tweeters/speakers in 2 of your gauge spots? If so what did you use? Which gauges did you remove? Did they work well?
CSM11 is offline
post #2 of 6 (permalink) Old 11-30-2013, 04:31 AM
You should be able to search the audio threads, (or hopefully somebody will post some of the links), it has been done by a few. As far as gauges removed, air temp is definitely the first to go, I forget the other. I personally use all my gauges and replaced the air temp with an oil temp gauge. My tweets are mounted in the speaker grills.
Sent from my SPH-L710
post #3 of 6 (permalink) Old 11-30-2013, 09:39 AM
RichieRich's Avatar
I'd get rid of the fuel Gauge and just go off my trip meter. I agree with DBell though, there are other places to mount a tweeter that achieve the same effect. The metal Hawg Wired grills can be cut to accept a tweeter.
Sent from Motorcycle.com App
2013 BBP FLTRX
RichieRich is offline
post #4 of 6 (permalink) Old 11-30-2013, 11:00 AM
Hawgwired grill cut for tweeters.
post #5 of 6 (permalink) Old 11-30-2013, 01:08 PM
ldireprophil's Avatar
My cvo already had tweeters, so it was a quick speaker upgrade for me. I would think swapping the gauges for speakers would be a relatively easy undertaking. Maybe someone who's done it will chime in soon.
ldireprophil is offline
post #6 of 6 (permalink) Old 12-01-2013, 11:10 AM
JMJOHN
JMJOHN's Avatar
custom plug-n-play Gauge tweeter kit for your RoadGlide here http://www.jmcorp.com/ProductDetail....=HTWT-1025-CRF ,,,,,
easy to install, easy to connect ,,,,,
J&M Black-Friday 20% promo code 314PFB211 ,,,,,,, www.jmcorp.com ,,,
JMJOHN ----
JMJOHN is offline
Aquatic AV-JL Audio HX280/4-Polk Audio MM652s, SMD DD1 rustyj671 Audio 6 08-22-2017 02:49 PM
Car audio vs motorcycle audio sdlakerfan79 Audio 20 04-11-2013 06:52 PM
Zumo GPS Audio Output question J-J,DE GPS 23 01-02-2013 06:48 PM
2011 CVO owners, Boom audio/ amp question DED HD Aftermarket Accessories 4 12-02-2010 05:44 AM
Harley Boom Audio Speaker question abone Aftermarket Accessories 3 04-15-2010 08:11 AM
