Fuel Moto 107" hi output R&D motor 151Hp Pump Fuel - Road Glide Forums
post #1 of 6 (permalink) Old 01-14-2014, 12:39 PM Thread Starter
EFI tuning and Exhaust Expert
fuelmoto's Avatar
Here are some results from some recent 107 development and testing we did. Note this was a full effort, fully developed build by Fuel Moto with assistance from several other key partners including Gary Williams & Bobby Wood. The charts in this thread are a result of several weeks of work & dyno testing/swapping/building/modifying various components
2010 FLHX test bike
FM 107" IC cylinders
custom MTC pistons 12.5 comp
Gary Williams cylinder heads
Wood TW68G-7 cams
Darkhorse lower end with H beam rods
SE58mm TB (modified)
Jackpot XXX exhaust
tuned with Dynojet Power Vision
PUMP FUEL
Run Data:
RunFile_019.drf: 63.04 °F 29.15 in-Hg Humidity: 7 % SAE: 1.01 Average Gear Ratio: 45.87
s RPM x1000 hp ft-lbs
0.25 2.60 40.92 82.70
0.45 2.70 43.69 84.98
0.63 2.80 47.93 89.89
0.79 2.90 53.70 97.23
0.95 3.00 59.97 104.97
1.10 3.10 65.32 110.64
1.25 3.20 69.93 114.76
1.39 3.30 73.58 117.11
1.53 3.40 76.31 117.87
1.67 3.50 79.18 118.82
1.81 3.60 83.00 121.09
1.95 3.70 86.13 122.27
2.08 3.80 89.02 123.04
2.22 3.90 92.66 124.78
2.35 4.00 96.43 126.61
2.48 4.10 98.54 126.24
2.62 4.20 101.84 127.35
2.75 4.30 104.79 127.99
2.88 4.40 107.16 127.92
3.01 4.50 109.53 127.84
3.14 4.60 112.36 128.29
3.28 4.70 114.60 128.06
3.41 4.80 116.91 127.93
3.55 4.90 119.25 127.82
3.68 5.00 120.65 126.73
3.82 5.10 122.42 126.07
3.96 5.20 124.68 125.93
4.10 5.30 126.23 125.09
4.24 5.40 128.41 124.89
4.38 5.50 130.11 124.25
4.52 5.60 132.05 123.85
4.66 5.70 133.81 123.30
4.80 5.80 136.46 123.57
4.95 5.90 136.31 121.35
5.09 6.00 138.90 121.59
5.23 6.10 141.99 122.25
5.38 6.20 143.36 121.44
5.52 6.30 145.53 121.33
5.67 6.40 147.25 120.84
5.82 6.50 149.63 120.91
5.97 6.60 151.96 120.95
6.15 6.50 61.60 49.53
6.34 6.40 34.99 28.57
6.42 6.30 -6.11 -5.31
MAX: 6.42 6.60 151.96 128.29
MIN: 0.25 2.60 -6.11 -5.31
Jamie Long / Fuel Moto USA
Contact 920-423-3309
Email
fuelmoto is offline
post #2 of 6 (permalink) Old 01-14-2014, 12:44 PM
Deadstroke's Avatar
Why do you hate me!!!! LMAO!
Just came to a decision on what I was going to do and now you post this..
Deadstroke is offline
post #3 of 6 (permalink) Old 01-15-2014, 12:54 PM
PFWiz's Avatar
Just like a gorgeous, sexy woman winking at me and the driving off....
It turns me on, but I know I am not gonna get any of that...
PFWiz is offline
post #4 of 6 (permalink) Old 01-15-2014, 05:25 PM
Redbeard77's Avatar
Great output from a 107, but do you foresee any demand for a setup like this? Unless someone was racing in a class with a displacement limit, wouldn't you expect someone investing that much to go with more cubes while they were at it? To that point, have you done an equivalent build with your 117 kit?
Happiness is a warm motorcycle.
Redbeard77 is offline
post #5 of 6 (permalink) Old 01-16-2014, 09:04 AM
Durwood's Avatar
That's a Bad Boy there! Not your grocery getting 107" engine for sure .
This shows the potential of the FM XXX exhaust, I like it, stainless, ALL the O2 bungs for the DIY tuners and use stock heat shields.
I bet this pipe setup would be right at home on a stout 124.
Keep up the good work Jamie
Don't forget the tune.
Durwood is offline
post #6 of 6 (permalink) Old 01-22-2014, 08:24 PM
adrenilinecrash's Avatar
Not to doubt hours of work, but... Is that on a chasis or engine dyno? What are the stats on the heads?
02 FLTRI
15 FXDL
adrenilinecrash is offline
2016 RGS with Fuel Moto 107 High Output BrownSanta Dyno Results 5 02-26-2017 09:08 AM
New Extreme Duty 98" 107" & 110" Drop In Fuel Moto Cylinders fuelmoto Fuel Moto 0 12-13-2016 12:54 PM
11 RG Fuel Moto Hi Output 117 build fuelmoto Dyno Results 3 03-18-2014 12:49 PM
New Fuel Moto 117" Hi Output engine package fuelmoto Fuel Moto 48 10-07-2013 12:24 AM
